Does anyone have AC and regret it? Anyone rip it out? Anyone
Seth Horwitz
Does anyone have AC and regret it? Anyone rip it out? Anyone need it?
25 members have voted
  1. 1. I've seen a few happy customers, but others have overheating or lost power. So ...
    • Love my AC!
      16
    • Hate it / Ripped it Out / Wouldn't Add it for Free
      9
2 hours ago, tme said:
Mike,
Do you recall what rotary compressor you are using and anything else that you changed assuming I stick with R12?
 Thanks
I believe the majority of us use Sanden, or Sanden knock-off, rotary compressors on Hobie-Dave compressor brackets. If your A/C has not been refreshed in recent decades, a new expansion valve and a new drier are probably in order. I still run R12 in the ‘76’s Clardy system. We did a complete re-fresh in 2012. The evaporator/blower is original, as is my Clardy condenser. But, given that the system was open, and apart, in addition to the compressor, compressor bracket, expansion valve, and drier, we replaced the hoses. Did we need to? Perhaps not, but they were 36 years old, so....
I have even been using the ‘76’s original Clardy auxiliary fan, until now! I’ll be frank, it’s a cheap homemade device that Clardy provided. It draws so many amps to move so little air, however, that I am considering a modern Spal fan to replace it.
Below, original Clardy condenser and auxiliary fan.
Edited by Conserv
Purchased my 73 that originally had a BEHR installed. The previous owner had removed the compressor and condenser along with its engine compartment hoses.  Living in SLC, summers can get quite hot, so I bought a electronic controlled DITEC  unit and outsourced hoses, condenser, Spal fan, Hobie Dave bracket & Sanden rotary compressor. Removing the original BEHR unit and installing the DITEC was not an easy task. Took a lot of pounding on the trans tunnel to make the base portion fit, not to mention the firewall alignment issue for the heat & Freon fittings exit. If I had known that the unit also came with a side fitting exit rather than my forward exit, that would have been my choice, as I could have used the original hose paths and eliminated additional firewall holes. My system is now installed with the remaining task of figuring out the wiring, as the supplied instructions for a 2002 install were vague & minimal. I still have the original BEHR unit and control cables that I am willing to donate locally (too lazy to ship).
Purchase my 73 that originally had a BEHR installed.docx
1 minute ago, bobthomas said:
I live in eastern NC & you can have my AC when you pry it from my cold dead hands.
The trip I mentioned above was to New Bern, NC with my wife.  Our inner elbows were "comfortable".
I live on the surface of the sun (Sacramento) so AC is a must for 6 months out of the year.  Just today I charged up my new system for the first time and cannot wait for some warm weather.  My system specs:
Original Clardy evaporator/fan
@02hobiedave bracket
Chinese Ebay Sanden compressor
11 x 21 climaparts parallel flow condenser
Spal 30101505 12" straight blade fan
With this setup I managed to get 33 degrees out of the vent at an ambient 80 degrees in the garage!
I have a friend in McLean VA that ripped his ac out because he wanted more room for Performace upgrades.  I bought his entire IcE setup and it’s all sitting in a box waiting for me to get to that portion of my project.  I will install it, but I must say that asthetically speaking- the console is not the most attractive set up. I have been eyeing some variations made by koogleworks.
And as a a back up for really hot days there is always this $20 dollar option.  A homade DIY.
Edited by Dionk
I hate to say "buy my book," but BUY MY BOOK! I go into a mind-numbing level of detail on most a/c related topics, including the basic recipe for rejuvenation:
--If the car has a/c, re-use the stock evaporator assembly (the unit under the dash and surrounded by the console), but replace everything else.
--Sanden clone compressor and Hobiedave bracket.
--Big parallel flow condenser.
--Big fan.
--New receiver/drier
--All new hoses.
If the car DOESN'T have a/c, there are a number of options, but for most people, the easiest and cheapest is buying a used stock evaporator assembly and console. I'm all for the folks who have installed the ICE or DTECH systems or one of the small integrated climate control heat/evaporator boxes, but I haven't done it myself.
Rob
https://www.amazon.com/Just-Needs-Recharge-Mechanic-Conditioning/dp/0998950718
1972 tii (Louie), 1973 2002 (Hampton), 1975 ti tribute (Bertha), 1972 Bavaria, 1973 3.0CSi, 1979 Euro 635CSi, 1999 Z3, 1999 M Coupe, 2003 530i sport, 1974 Lotus Europa Twin Cam Special (I know, I know...)
--Big fan.
--All new hoses.
Rob
What he said.  Rob's book is invaluable in this process.
Edited by \\\Mink
11 hours ago, tme said:
Mike,
 Thanks
When I bought it, they were Sankyo; I believe now that they're Sanden.  AFAIK they're essentially the same unit.  I didn't change anything else, and for many years used a piston compressor to rotary compressor adapter on the original bracket.  I now use the "Hobie Dave" style bracket that was made for a rotary compressor.
Otherwise, the remainder of the Frigiking system was what the dealer installed back in 1973.  Oh, and I added a pressure switch--that shuts down the compressor if the Freon leaks out.  When that happens, the lubricant goes with it and will crater your compressor in short order (ask me how I learned that!)
depends where you live and how you drive.
I live in the PNW. I dive 5+ times per week. when I bought the car, my system was non-functional. I considered getting it working, or even a new system, but ultimately decided I don't need it.
Edited by joebarthlow
1974 BMW 2002 (Polaris > Sienabraun)
I live in N Florida so having air is a great option I've enjoyed on two of my 5 2002's.  I added the optional fan that came with the 75 or later A/c versions and I've never had a heating problem even driving in city traffic.  For my performance 3 series engine versions I wouldn't think of it.
74 2002 w/ac & sunroof
71 2002 M20/260
75 2002 parts car
74 VW Westfailia bus
70 VW Weekender bus
2012 VW Jetta Sportswagon
2 hours ago, Mark92131 said:
In SoCal, this is all the air conditioning you need, ;-).
Mark92131
In Australia, people always regret buying convertibles as the sun is too harsh (thin Ozone layer) and you get sunburnt within minutes.
I love the idea of one too (been thinking about a Z3) but I reckon that the top would be up more than down. Not sure how the sun differs in California but I hope that convertibles are still useable there.
rtheriaque wrote:
