1 hour ago, AndySals said:
I fit Bilstein dampers on the rear a couple of days ago. Today i heard my exhaust blowing at the front end and found that two of the nuts holding the downpipe to the manifold were missing! An easy fix tonight
Must of installed those sport versions that shake all your guts loose :)
  • Haha 1
Reinstalled a fuel check valve and pre- (mechanical) pump fuel filter, trying to figure out a dry float chamber on my carb on a warm (not hot or cold) restart. Not sure if it was vapor lock or fuel system crud, but I took a shotgun approach. Now for the proof of the proverbial pudding...
-Dave
Posted from my phone.
Colorado '71 2002
'17 VW GTI Sport
Fuel line draining has nothing to do with the bowl going dry.  Whatever is in the bowl when the line drains stays there just like you toilet tank would not suck back.  It's the air break at the fill valve.
10 hours ago, Obtuse443 said:
Can you show a picture of the fuel check valve?  Is it standard on the typical 2002 fuel line?
It's aftermarket, not factory. I didn't snap one of mine, but it's the same valve and location as Tom (76Mintgrun) installed in this thread:
Technically, the mechanical fuel pump should function as a check valve, but I do notice faster starting/less cranking with the aftermarket valve in place.
I know that, Jim; I just wasn't complete enough in my description. The problem seemed to be that the bowl wasn't refilling on a warm start--i.e., the pump wasn't pumping enough to replenish what was being pulled from the bowl. So it would start and run fine for a minute or two, then stall once the bowl drained. It would sometimes seem to get a tiny bit of gas flowing, but just enough to maintain a low idle. Attempts to accelerate resulted in a stall. Thus my attempts to combat the possibility of either air in the line before the pump or debris fouling the pump (though the pump screen was clear). Admittedly, adding a filter before the pump addresses the latter while having a potentially negative effect on the former, but I feel better with the filter there.
Thanks for keeping me honest!
-Dave
Colorado '71 2002
'17 VW GTI Sport
I installed a 1000 Watt Pioneer amp under my rear seat delete and a pioneer head unit under my dash cause I have deleted my console as well. The MB Quart speakers hidden under my parcel shelf sound great! I've got music!
1974 2002 Tii-SOLD
1978 911SC Coupe
1988 Landcruiser
2020 M2 CS
My "final" button-up for the interior. Got the last of the brite work installed... brushed chrome door moulding,  IE billet handles,  and cerakoted an old rondel for the last personal touch.
Ready for an ONR wash and a couple of C & C events  this weekend (weather permitting)
FullSizeRender.thumb.jpg.6a6358cbc8cf0d44ec1d42b457cb6f4f.jpgIMG_2460.thumb.JPG.991b6abd3d5969699951351261812f2d.JPG
IMG_2465.thumb.JPG.f61179ea185faa53360c130876e58451.JPG Special thanks to VanCity Plating for the fabulous work.
  • Like 14
De-shrouded intake valves and tweaked the chamber on E12 casting head (next-up = porting) - all part of a plan to flow-test, specify and build a repeatable, performance street M10 from carb(s) -> intake -> cam -> pistons -> header -> exhaust tip. “Stage ???” -KB
