Lots and lots of cleaning of the donor block and associated parts.
Oil contacting surfaces and passages of the block are maybe 76.5% done.
Also ran taps through all the exterior bolt holes, experimented with wire brushing the exterior to remove the paint and it works pretty darn well, so that'll be my approach to stripping the block.
And also began stripping apart the pistons/rods to strip the corrosion off of those as well, and lightly polish mating surfaces.
And to top it off... painted the resonator of my Abarth exhaust with VHT flameproof paint. It looks so good now I feel obligated to paint everything else on the exhaust system. Maybe.... if I have time, but I don't think I do.
Trip down the I-5 to check out the project at Midnight MS and lunch at Zippys with a couple of friends .
A good day
Suspension  all buttoned up. new brake lines in.....driveline is not far off now......hopefully!
IMG_0864.JPG.c5f07ac40b60395d4d1c742ef5450dfc.JPG....
and some of Patrick's magic shortening the e-brake for the centre console
  • Like 3
52 minutes ago, Fatherof3 said:
Replaced my front fenders
Looks great, but upon closer inspection, your steering wheel's not original.  Concours judges will dock you a couple points for that...
1973 BMW 2002 (Verona)
1975 BMW R90S (Silver Smoke)
Just something simple.
Replaced the aging batterey and it starts nice and nice and goes hard.
Will attempt tomorrow to reverse flush flush the heater core.  Wish me luck that I don't open a hornets nest.
  • Haha 1
1974 2002 2.2stroker, DCOE45's, 300deg cam, 5 spd, 3.91 LSD // 1984 E24 M635csi, dogleg 5spd 3.23 LSD. // 1994 E34 540i, supercharged 16psi, 6spd E85 only, 3.15 LSD // 1997 E36 M3 Evo, low comp supercharged 18psi 6spd (under construction)
6 minutes ago, kbmb02 said:
Fired up a new M10 build, it'll be shipping to Las Vegas this weekend. -KB
(hmmm.. video won't load into the page)
IMG_3640.MOV
That was awesome short clip!
What's your VIN/mfg date? I have a 74 Verona too :)
  • Haha 1
'74 Verona
Firstly, I like your trunk light. You won't lose anything in the dark with that on.
Secondly, what are you using for a replacement wheel well base?
rtheriaque wrote:
I use rare earth hook magnets and a twin tube lamp, no excuses for not seeing things! I'm using a clean 320i well I bought on eBay. The 320i well is about 10-12 mm narrower in diameter than the 2002. I will be flaring the 320i well edge out for a tighter fit pre welding. I also have to swap the threaded post for the spare and move the "tow hook" to the right location.
17 minutes ago, kbmb02 said:
bzzt. bzzt. bzzt. ....   -KB
Very nice.  Some strategically placed texturing and you're good to go!  Or not.
