Tii Rotors Nla?
TobyB
Thanks for the perspective Andrew. That helps re-set my expectations about cost. Looks like I'll have to bite the bullet on these when the time comes.
James
1987 Porsche 944 Turbo (sold)
1973 Mintgrun 2002 "Kermit" (sold)
1973 Inka 2002 "Ernie"
1986 VW Vanagon Syncro Weekender "Otto Van Gonzo"
If you have a tii, upgrading to a vented setup may be worth the trouble.  (E12 calipers, E21 hubs) Vented E21 rotors are readily available and are not near as expensive.
The upgrade is completely reversible if the need ever arises.
Pierre
O==00==O
69 2002 (M20), 74 tii, 76 533i, 79 323i, 80 732i, 84 323i (S50) 91 318is, 96 318ti (S52), 97 Z3, 02 330i, 03 525iT, 02 R1150 RTP.
Auxiliary Lamp Brackets  Kamei Reproduction Front Air Dam
Wahoo! Just ordered a pair, glad they are available.
Andrew Wilson
  • 3 years later...
On 4/23/2014 at 5:47 PM, John_in_VA said:
Centric shows this rotor for the tii.  Any idea if it will really fit?  They are available from Olympus Imported Parts here in northern VA.
Front Premium Rotor Part Number:  120.34002 Manufacturer:  CENTRIC PARTS    City of Industry, CA    626-961-5775 910482952.jpg
 I placed my bet on these rotors. Have not been able to fit the calipers . Has anyone had a similar problem?
73 Tii stock build, Porsche Macan   , E46 330i Florida driver,
….and like most of us, way too many (maybe 30 at last count) I wish I hadn't sold ?
Bolt circle - 4 x 92mm is your problem. Close but no cigar as they say.
rtheriaque wrote:
That’s not a problem, IF you remember how ‘02 front brakes bolt to the hub.
Tom Jones
All the parts are factory original except the rotors and replacement bearings and races. The problem is when positioning the caliper the rotor is not centered within the caliper’s free space (obviously  forcing it to one side and not allowing the mount to align , both sides same problem).  I was pretty certain that the races were bedded properly. The diameter isn’t an issue, it appears to be a dimensional problem with the offset from the mounting face to the hub.
Edited by Mike A
Did you something like the factory manual suggests to snug up the bearings?  (see below).  Try comparing the "height" of the old rotor to the new rotor.  The height being the distance from the inside face of the rotor to the top of the cap.
BMWCCA  Member #14493
www.2002sonly.com
^^ I ll try refitting the  bearings using that procedure ....
....but still looking for anyone who has installed these Centric rotors
Edited by Mike A
