Tii Rotors Nla?
TobyB
I got a set of E12 calipers (77 or newer) from O'Reilley's for $58 each.  They wanted $18 for cores.  (I had cores.)  I have a friend who got calipers for $42 each from Autozone.
I don't know if it's legal for racing, but installing early (up to 79) E21 hubs with E12 vented calipers and 77-only 320i vented rotors (or any 6-cylinder E21) will get you a bolt-on brake upgrade and available parts.  How much are tii calipers?  How about rotors?
I think sourcing the hubs would be the hardest part, and that's not really hard.  I got 2 sets from Sherman a couple of years ago.  And Ireland has the rotors, solid, or drilled and slotted.
Or wait for tii rotors to come back.  And buy 2 sets.
Pierre
O==00==O
69 2002 (M20), 74 tii, 76 533i, 79 323i, 80 732i, 84 323i (S50) 91 318is, 96 318ti (S52), 97 Z3, 02 330i, 03 525iT, 02 R1150 RTP.
Auxiliary Lamp Brackets  Kamei Reproduction Front Air Dam
My original Q was because an F- production 2002 has to use tii rotors and calipers...
I keep thinking that my E-Prod loser would make a pretty good F- prod contender
because about all I'd have to do is take off the nice, big E21/late E24 brakes...
JohnS, would you mind taking a pic of the boxes, if you still have them?
Thanks,
I thought about upgrading to vented rotors, but I'm set on using my stock 13" tii alloys and stock 13" steel wheels on my tiis, so was afraid that the common vented rotor upgrade for the tii might not fit under my stock wheels.  I was also considering a kit that Walloth & Nesch sells to upgrade tii calipers to Turbo style and then use the Turbo vented rotors.  Does anyone know what type of hub is required for the Turbo rotors?  Also, would the Turbo rotors and calipers fit under stock tii 13" wheels?
@TobyB ... I'll take a pic of the Rotors and the box when I get home tonight.  The box is all white with nothing else on it except a cut-out spot.
Cheers,
John
Edited by JohnS
'73tii Inka 🍊
'74tii Fjord 🏄‍♂️
On 1/8/2015 at 10:41 AM, JohnS said:
... Also, would the Turbo rotors and calipers fit under stock tii 13" wheels?...
I have no actual experience with this, but since the standard factory turbo rim was 5.5"x13" ET18 (and the optional turbo version of the alloy was 6"x13" ET13), I suspect that neither the early tii steel rims, nor the early OEM alloys, nor the later styled-steel rims -- all of which are ET26 or greater -- will fit over turbo calipers without some...modification.
But if I'm wrong, that would be good!
Edited by Conserv
Turbo caliper cross reference:
Part 34111101859 (CALIPER WITH OUT BRAKE PADS LEFT) was found on the following vehicles:
114: Details on 114
114 2002turbo Sedan, Europe
E12: Details on E12
E12 518 Sedan, Europe
E12 520 Sedan, Europe
E12 520i Sedan, Europe
E12 525 Sedan, Europe
E24: Details on E24
E24 630CS Coupe, Europe
E24 633CSi Coupe, Europe
E3: Details on E3
E3 3.0Si Sedan, USA
E3 2.8L Sedan, Europe
E3 3.0L Sedan, Europe
E3 3.0S Sedan, Europe
E3 3.0Si Sedan, Europe
E3 3.3L Sedan, Europe
E3 3.3Li Sedan, Europe
E9: Details on E9
E9 3.0CS Coupe, USA
E9 3.0CS Coupe, Europe
E9 3.0CSi Coupe, Europe
E9 3.0CSiL Coupe, Europe
E9 3.0CSL Coupe, Europe
Turbo rotor cross reference:
Part 34111152092 (Brake disk) was found on the following vehicles:
114: Details on 114
Heh,..
Ray
Looks like the Turbo hub (part #31-21-1-103-797) is unique to the Turbo, just like the Turbo rotors are.  Since I have some spare calipers for my 3.0csi coupe, I guess I've already got some "Turbo Calipers".  Oh well, she's staying stock for now...
'73tii Inka 🍊
'74tii Fjord 🏄‍♂️
-Bob
(current: 1972 Malaga 2002, VIN 2584644, build date July 26, 1972)
Previous: 1973 Sahara 2002 #2585896 (RIP), 1969 1600, 1971 2002, 1964 Triumph Herald convertible, 1965 Triumph Herald convertible, 1961 Triumph TR3A, 1967 Triumph TR4A-irs, 1959 Austin Healey 100/6, and about 10 other cars (most of which were quite boring)...
  • 10 months later...
So any update on Tii rotors? Are these available again stateside? WN currently selling for $104 each (converted to USD) before shipping. Yikes.
James
1987 Porsche 944 Turbo (sold)
1973 Mintgrun 2002 "Kermit" (sold)
1973 Inka 2002 "Ernie"
1986 VW Vanagon Syncro Weekender "Otto Van Gonzo"
Just installed a set from Walloth & Nesch.  Seem to fit and be functioning fine.  No longer have the shimmy upon braking.  Not cheap, but better than trying to stop the car with warped rotors every time.
Edited by LarryE10E20
Larry
'73 tii
'73 3.0 CS
'23 M2
