On 12/29/2019 at 12:53 AM, The Judge said:
Finally got my valve cover on the built motor, now I just need to get a new oil cap.
I like the air filter! I'm just about to install dual DCOE 40's on my '73. What is the brand / model? Is that a non-tii brake booster?
thx
M
10 minutes ago, flagoworld said:
Now that the busy holidays are behind me, got to spend a but of time prepping some parts for paint
I don't know., Ryan, even after you finish painting that cardboard it's not going to look new.
What?
Oh.
:D
  • Haha 2
Ray
Started AC install! Going a lot smoother and quicker than expected. Needed to stop since I didn't have a 7/8" hole cutter.
I may take some detailed photos to share as the diagrams in the kit can be hard to follow.
  • Like 3
'98 M3
'74 2002 Touring
'01 750Il
'96 B3 3.2 Touring
Aardvark provided the door panels.  He sent me the green clips.  They bite in to the door metal when I push them in but barely.  They pop out on their own.  The door originally had clear plastic inserts in the holes.  They are all gone.  I think they helped allow the green clips bite in to the door better.  Do you know if those clear plastic inserts are available?
It appears as though the green clips don't push in far enough due to the way the vinyl is wrapped around the door card.  That is all I can deduce.
Try pushing harder? Are the clips loose at all in the door panel material?
You may want to razor off a little of the extra vinyl on the backside of the panel? Could try last resort to press down the overlapping areas with some heat to flatten it.
Sent from my SM-J327VPP using Tapatalk
Happy new year!
Today I made a little more progress...
Painted some bits
Designed and printed this TPS adaptor plate in PETG... should be durable enough to withstand this use case no problem. Theoretically, anyways.......
Started designing some parts of the intake tube for printing. The IAT will screw into it.
  • Like 3
'74 Verona
Here you go...
https://www.wallothnesch.com/en/door-clip-sleeve-set-of-10-pieces-15907.html
1972 BMW Inka 2002Tii  ?
1974 BMW Turkis 3.0 CSi ?
1972 MBZ Weiss 280SE 4.5
2006 BMW Cobalt 530i (38,700 m original)
Tried to adjust the rear drum-shoes, but they did not need it.
Then I bled a little clean clear bubbleless fluid out of the brakes
and then this blackness oozed out of the clutch slave.
That made it all seem worthwhile.
I pulled my new battery out to take a photo of the postal damnaged corner
and put the important warranty sticker on the front end, out of sight
and UpGrAdEd the hold down.
the little hose keeps the clamp on the screw
the bigger piece adds a bit of bling
it matches the dipstick now
Edited by '76mintgrün'02
  • Like 3
18 hours ago, kbmb02 said:
Installed a new E12 piston in preparation for checking clearances.
Very nice!
And what compression ratio does that design yield, Ken? Just curious. ?
Thanks and regards,
Edited by Conserv
Thanks and regards,
As I've probably noted here before, the benefit of custom pistons is they're designed and machined to specification: usage/application, cylinder size, block height, head thickness, combustion chamber volume after head work / valve job, camshaft lift*, etc (*some ignore the camshaft spec - it's why you see disclaimers, or over-size valve pockets). Anyway, to answer your question:
Those pistons spec out to 13.4:1 for a big-camshaft, dual sidedraft race engine. -KB
