34 minutes ago, FunElan said:
Got the car on the wheels and it started up!! Still worried about the giubo which isn't exactly parallel...thinking I need a new driveshaft.
Could be a few things to distort the guibo.  Engine mounts, diff mount, csb, diff position.  All things that are far less costly or may just need adjustment.  Good luck.
73 Inka Tii #2762958
One of the things we tried was to undo the diff mounts to the axle (and the hanger) and to slide it forward. It ended up moving the trans and engine with it when we push it forward with a big screwdriver. CSB is preloaded 2mm. Didn't think the engine mounts had that much room to slide forward?
'68 Caribe 1600-1563167
1 hour ago, FunElan said:
to slide it forward
First off, I'm only speaking from my experience. There are others here with professional knowledge that likely have the best advice.
What I've learned, mostly from this forum, is that the diff position is the last adjustment to be made if the powertrain has been re&re'd and everything is disconnected.  I would first check the distance of the fan from the rad. 3/8" to 1/2" gap is optimum.  Double-check that the stop on the passenger side motor mount is properly situated. Once the motor and tranny mounts are secure and undistorted, attach the guibo and csb, making sure that there is no left-to-right mis-alignment.  If there is vertical distortion of the guibo, the csb arms can be bent slightly to correct this.  Finally the d-shaft is connected to the diff.  What I've found is that there is usually a small gap between the d-shaft flange and the diff.  In your case the diff may be too far forward, distorting the guibo.  Could it be that your diff needs to be further back?
Pre-loading the csb shouldn't change the profile of the guibo.
That's all I've got.  ☺️
Edited by PaulTWinterton
post a pic and see if the d shaft is too long or short. I'm betting its too short and the guibo is being pulled backwards at the 3 points of the flange..
In that case you 'll have to muscle the diff forward...call rent an ape.com
*all dependent on how much adjustment you have left in the diff' 'slots'
Edited by iinca
I think you’re right, however there wasn’t a ton of room for the diff to keep moving forward. Might have to try motor mounts as well
5 minutes ago, Bibm5 said:
Just got caught in a rain storm for the first time in the 2002 since bodywork emoji24.png5019e1c4fede8f4c6b5e3ec39c27fa3c.jpg
Sent from my SM-G960U using Tapatalk
I wish!!  Send that rain down to Norcross!
'72 2002Tii Inka   2760698
'65 Porsche 356SC
