Just put in Continental branded stereo (advertised as VDO), from Turner. A bit anemic compared to Kenwood that was in there, but form over function this time. Has BT streaming, BT hands free and USB charging. The basics.
Also, 2 rear tires. Waiting for two fronts. They “lost” one.
  • Like 3
I just installed a custom rear view mirror cover
I put two of them on the old Subaru as well.  Here is the reason.
The little juncos leave quite a mess, while defending their territory  from  their  own  reflection.
(googled image)
How to Attract Juncos to Your Yard
I wonder what he'll do with all his free-time today...
Tom
  • Like 4
  • Haha 3
Hey Tom,
I hope that works out. Most of our flying friends around here would shred that to line their nest.
Question: What size sock is that?....
1975 Malaga. It is rusty but runs. Just like me.
I cut off the lower part of an old AlpacA sock.  Size men's large.
( alpaca socks are the most comfortable socks  in  the  world ).
edit--
Speaking of nests, this little finch sure found some nice fluffy building materials and a fine place to put them!
That's out in the greenhouse (garden shed, these days).
I'm sure they've hatched by now.  I should go take some more photos.
Tom
Edited by '76mintgrün'02
  • Like 4
On 6/13/2020 at 9:08 AM, AustinOski said:
Sheepishly posting, having Terry Sayther do the work while others are doing their own metal fabrication...
No way bud, this is all just fine.  Get the car working and running properly- it's so much more enjoyable when it's all working right.  No shame in paying an expert.  We may all have different skills, but we all love driving our cars.  Get it running and enjoy it!  (I think many of us have no choice but to figure it out ourselves because there's no one around to simply pay to have it done...)
Dave.
Went on a great drive in the Texas hill country between Austin and San Antonio With The Tejas chapter...thanks to Paul Goldfine for the pictures.C7528233-D32E-4855-AF30-917B19C45461.jpeg
  • Like 3
make nothing happen…
@irdave - Thanks for the support. Hey, I did fix a jammed door lock/handle yesterday, cleaned-up some surface rust under the moisture barrier in the door, added some butyl to the inner panel and didn't figure out why the window is sagging towards the read of the car as it's rolled-up - there is some movement in the guide at the rear. Oh, wait, I pictured it in my head as I typed. I may just have an idea!
And, maybe most importantly, I took a friend for a ride yesterday. He laughed he was having so much fun! I may have exceeded the posted speed limit once or twice!
Edited by AustinOski
1 hour ago, Highnote1 said:
Going in for paint July 1!
Fixed some rot in trunk that was hiding. Little more work than I thought but got it!
Curious. What year is your car? My ‘76, for which the only other rust was on the front fenders, had that box section between fuel tank and right rear quarter rusted out. And, it had pretty much rusted out by 1981!
76!! I was very disappointed to find it and the cause being the bracket underneath it Holding grime that looked like a bad idea from the factory to me. Was that add on bracket a “safety” add on? Would have loved to have not had that down there. It was also hard to remove gently. Quite a mess. I’m tired.
Finished cutting out and test fitting the underdash panels. Next I have to cover them in vinyl.
Also picked up a couple edis ignition capacitors [condensers] from the junkyard. I installed one and appear to have noticeably decreased my ignition noise. The factory systems all have these capacitors because otherwise theres a lot of flyback voltage spikes getting pushed back into the coil supply line. TIL.
'74 Verona
The component below the floor was originally a closed box section, reinforcing the floor in the event of a collision. It was approximately a foot long. It might have had a drain, but, despite having had my ‘76 from new, I never examined that particular area — wedged between the fuel tank and the quarter — until I found a rust hole in the underside of the box section, which might have originated around a drain.
Virtually every ‘76 I’ve seen has a rust issue around this box section.
