Nomenclature: 2002 Vs '02 Vs E10
RAS-2002
Just curious: when did the 2002 start being referred to as an 'E10'?  I guess I've been in the dark for the 30 years since I last owned a 2002, so please pardon my old-timer ignorance.
I bought my first 2002 new in late 1972, and until I bought my latest (another '72) last year, I hadn't heard of them being called anything but a 2002 or an '02.  When I started going on-line, checking out all the 2002 forums (forae?), I kept seeing references to "E10 this" and "E10 that", along with 2002 info.  For awhile, I had no idea that they were talking about the same thing. When did this 'sea-change' take place?
What terms do you all currently use to refer to your cars?  "My E10"  "My 2002"  "My '02"  "My 02 Bimmer" etc, etc.
Also, I've seen references to 'model 114' and 'model 2552' in regards to 2002s. How do they figure into the scheme of things?
Kripes, I hope I'm not going to be opening up a can of worms....
Thanks for any input.
Bob
-Bob
(current: 1972 Malaga 2002, VIN 2584644, build date July 26, 1972)
Previous: 1973 Sahara 2002 #2585896 (RIP), 1969 1600, 1971 2002, 1964 Triumph Herald convertible, 1965 Triumph Herald convertible, 1961 Triumph TR3A, 1967 Triumph TR4A-irs, 1959 Austin Healey 100/6, and about 10 other cars (most of which were quite boring)...
If I had to guess, the use of the e10 nomenclature came only after the explosion of BMW models through the '80's and '90's. And the range and number of models within each class seemed to simultaneously expand, while model names were re-cycled for very different cars. To say "535" doesn't tell you whether you're referring to a 1988 or a 2014!
If you asked me in 1973 how I liked my e10, I would have said "Huh?"! Come to think of it, if you ask me today how I like my e10, I'll probably say "Huh?"!
Edited by Conserv
They're all the same car with the exception of the "2552".  I don't know what those numbers refer to.
I call my car (which I've owned for 32 years) an '02 (usually on this board) or a 2002, but I know it's an E10 and also a Model 114.  Just add those numbers to your vocabulary and consider yourself more well-read and knowledgable.
Bob Napier
'75 2002A
'762002A
  • Haha 1
One thing is when you go into a dealership for parts its bloody useless telling them you want the parts for a 2002 BMW as you know whats going to happen , By using the E10 code at least you have a better chance of maybe getting the right part.
72/2002 Inca
72tii/2002 "Apple"
70/2002 "Five "
73/2002 "Freeda"
2007 Lotus 7 Replica
2011 Ford xr6 Ute
85 E30 325
70 1600-2 "Orange"
I feel as if when your trying to search for things on ebay or the internet when searching for "BMW 2002" or whatever you get information for a BMW made in 2002. With the e10 designation people have created, it gives you in some cases better results. Other than that I see no use. I personally refer to my 2002 as an 02.
76 Sahara 2002
I don't know where the 4-digit numbers come from, but doing a part number search on RealOEM shows them. For example, here are search results on applications for the rear wheel bearing seal, part no 33413404161:
Part Cross-reference
RealOEM.com Home
Language:
Part 33413404161 (Shaft seal) was found on the following 114 vehicles:
114 1602 Sedan, M10, MANUAL (2515) : SIDE SHAFT/WHEEL BEARINGS
114 2002 Sedan, M10, AUTO (2223) : SIDE SHAFT/WHEEL BEARINGS
114 2002 Sedan, M10, AUTO (2225) : SIDE SHAFT/WHEEL BEARINGS
114 2002 Sedan, M10, AUTO (2558) : SIDE SHAFT/WHEEL BEARINGS
114 2002 Sedan, M10, AUTO (ST16) : SIDE SHAFT/WHEEL BEARINGS
114 2002 Sedan, M10, AUTO (2224) : SIDE SHAFT/WHEEL BEARINGS
114 2002 Sedan, M10, MANUAL (2213) : SIDE SHAFT/WHEEL BEARINGS
114 2002 Sedan, M10, MANUAL (2215) : SIDE SHAFT/WHEEL BEARINGS
114 2002 Sedan, M10, MANUAL (2552) : SIDE SHAFT/WHEEL BEARINGS
114 2002 Sedan, M10, MANUAL (2214) : SIDE SHAFT/WHEEL BEARINGS
114 2002 Sedan, M10, MANUAL (ST12) : SIDE SHAFT/WHEEL BEARINGS
114 2002tii Sedan, M10, MANUAL (2233) : SIDE SHAFT/WHEEL BEARINGS
114 2002tii Sedan, M10, MANUAL (2583) : SIDE SHAFT/WHEEL BEARINGS
http://www.realoem.com/bmw/partxref.do?part=33413404161&showus=1&showeur=&series=114
I know what an E3 and an E9 are, but I've always thought of the 2002 as a type 114, though never refer to mine that way. It's a "2002". I have it easier with the 2002tii because I say I have a "tii" and that fixes the era the car is from (at least among to cognoscenti). It is only in the past decade I have heard E10 and I did not think that was correct.
FWIW, here is a list of relevant model codes from Wikipedia:
BMW Production series codes
BMW Typ100 — (1955–1962) Isetta
BMW Typ106 — (1957–1959) 600
BMW Typ107 — (1959–1965) 700
BMW Typ110 - (1961–1964) 700 Cabriolet
BMW Typ114 — (1966–1976) 1600-2, 1602-2002TI, 1502
BMW Typ115 — (1963–1964) 1500
BMW Typ116 — (1964–1966) 1600
BMW Typ118 — (1963–1971) 1800-1800TI/SA
BMW Typ120 — (1966–1970) New Class Coupé 2000C/CS
BMW Typ121 — (1966–1972) 2000-2000tii
BMW E3 — (1968–1977) 2.5, 2.8, 3.0, 3.3 "New Six" sedans
BMW E9 — (1969–1975) 2800CS, 3.0CS, 3.0CSL "New Six" Coupés
BMW E12 — (1974–1981) 5 Series
BMW E21 — (1976–1983) 3 Series
http://en.wikipedia.org/wiki/List_of_BMW_vehicles
--Fred '74 "tii" and '69 "widebody"
Edited by FB73tii
--Fred
'74tii (Colorado) track car
'73tii (Fjord....RIP)
Not so, BMW's parts program ETK defines the 2002 as a .... 2002.
Our local bmw has a hard time with me. I called asking about the aero style side skirts for a 2006 m coupe, and they said the m coupe was not made that year. I corrected them saying that the "m3 coupe" came out in 2008, but that the z4 "m coupe" was around in 2006.
I called for parts for my "1973 2002tii" and they got snippy and said "there was no ti in 2002, you must mean the 318ti". i said no... 1973, 2002tii. 2002 is not the year, it is the model. "what model is that? I have never heard of that!"
1973 2002Tii (Pacific Blue)
1984 911 3.2 Carrera (Platnum Metallic)
2009 328xi (Black Sapphire Metallic)
2010 Mazda Speed3 (Black Metallic)
All the round taillight '02 sedans are Type 114
'02 Tourings are E6
All square taillight '02 sedans are E10
2002 Turbos are E20 chassis
In the BMW labor times program all '02s are referred to as type 114
Nuff said.
Tom Jones
From reading the factory 2002 book (the orange cover BMW Profiles one), the two page (pp 24/25) reproduction of the original artwork for the 1966 1600-2 is labeled in the upper left corner "E114."  That covers the "coupe" body--the one imported to the US.  The book refers to the Touring as the 114K (drawing on the subsequent page).  There's no mention of  "E-10" anywhere in the book, nor in the parts book.  However I've also been told that E10 refers to the 02 Touring  body, the E114 being the coupe.  The number 10 would make sense, as the Touring body wasn't introduced until 1971, and follows logically the E3 and E9.  But at least according to the official factory book the whole 02 line was collectively referred to as design E114 (or 114K for the Touring).
UPDATE FEB 2020:  based on Jackie Jouret's 2002 history book, the original 1966 two door sedan was properly termed a "Type 114" vs "E-114."  The E-codes began with the E-3, a body style that post-dated the 1600-2... Just wanted to set the record straight.
cheers
Edited by mike
Tom, thanks, did not know that and good info. Can you provide a citable source(s) for this? If so, Wikipedia could be updated with the correct info, and G. Serpent could print it out and take it to the dealership when going there...... FB
'02 Tourings are E6
--Fred
