We had a playdate with his 630HP friend. I was proud of her, never backed down from that Chevy and said lets take it to the mountain roads....where gas stations are few and far between. Seriously, nice Chevelle down to the fuel pump...has anyone every seen a polished KF?
  • Like 4
Drive shafr came from the shop. Shortened to fit with Samsonas and new joints + balanced. Front struts are ready to fit the car. New for this season: m10 12.9 bolts to fasten steering arms.
Hmm tzei, sure the wheel studs are tall enough?  ?
Drive shaft looks about the same what mine forms up for F20C. So tempted to try one-piece again. It would be about 20cm taller than S2000 stock one-piece shaft...
Nice!!  Seems you have a lot of spacer for roll center correction. How short are your struts?
Dave
72'  2002 turbo build - under construction...
17 minutes ago, Mario Falfan said:
FWIW, I added sound dampener to the back of the plastic hinge covers, because I didn't like the sound they made when the seat belt receivers hit them.  Did the same thing to the shifter surround.  (in part because that stuff is fun to work with)
21 minutes ago, tzei said:
378 mm. Strut bottom to outer ball joint (centre) is about 90 mm.
 You must run pretty low?   How heavy are your springs and about how much travel do you think you use?
Ground clearence is MOT required minimum 90 mm (rules allows 50 mm). Mains are 110 Nm atm. Travel is 50-60 mm? Idk for sure.
