License plate thread
bluehills2002
@bluehills2002 I've had this exact question on my mind too. Particularly thinking about what to do with my original blue-plate CA car, now in Minnesota. MN too has a rule where you can find an original plate of YOM and, if the number isn't taken, put it on your car.
This said I'll always think of Otto as a Blue Plate CA car...
'73 Sahara numbers matching
YOM privileges were extended to Blue Plates in California a few years ago. I grabbed a set with ‘73 numbers for my tii!
January 30, 1973 Agave tii
April 24, 1974 Chamonix Turbo (German delivery)
They put WASHINGTON off to the left side, leaving room on the right for the tabs.  No tabs needed up front, so I used the paper cutter to slice WASHINGTON out of the plate; then put two holes in it and put it back on in the middle; with the height of the plate reduced by that amount.
I also made an 1/8" aluminum plate in that shape to screw it to.
I’m in MN and I looked into yom plates for my 75. The 74,75 plates in MN were 2 letters followed by 4 numbers AA 0000. When I called the dmv they basically told me anything in that form is reserved. I’d love to know if you find different info or a workaround.
