About my rebuilt engine ...
d.hitchcock
There were 3 different OEM "piano top" pistons for the E12 Head.  Each piston's piano was progressively thicker.
8.3 to 1 for regular 02s
9.0 to 1 for US spec Tiis
9.5 to 1 for Euros spec Tiis and built motors.
Hard to tell what you are running under that E21 head?  Either the pistons were modified (see 4th photo) or the E21 Head was modified for the piano top pistons.  If the head was decked, that will also change the compression ratio.  If the pistons are aftermarket (QSC), their "piano top" pistons are very aggressive (high compression).
Mark92131
1970 BMW 1600 (Nevada)
My ‘76 (49-state version) retains an E21 head. It has custom aftermarket pistons one might describe as “quasi-piano-top” to achieve a compression ratio of approximately 9.3 to 9.4. My ‘76’s head has not been shaved.
Edited by Conserv
If you have an e21 head and stock piano top pistons from an earlier M10, you aren’t going to have any compression because your pistons are going to interfere with, and bend your valves.
williamggruff
The head is off the car at the machine shop, so I'll get some numbers back to indicate whether it's been "pruned" before.
Thanks for all the background on piano-top pistons. The ones in my engine have no markings on the tops, but they look most like "Conserv's" to my untrained eye. They are evidently not piano tops from an early M10 as there is no interference.
Thanks, Steve, for the data points on your engine.
Edited by d.hitchcock
Not entirely true.
The spare motor I bought had e12 domed pistons and an e21 head.  It had been rebuilt (poorly) at some point in time.
It can work, but it's not recommended.
John Baas
1976 BMW 2002
2001 BMW M5
My Blog!
I am sure that a  BMW dealer actually recommended that I buy and the modify an e21 head to go with e12 pistons. Part of the squish area in each chamber of the head needed grinding away.  Not clear if that was BMW’s advice or just that guy.
Maybe in a post apocalyptic world I would do that so I was mobile enough that I could raid my neighbors for their irradiated water.
6 hours ago, xr4tic said:
Not entirely true.
Your experience was perhaps better than mine. The motor in my first 2002 had been rebuilt by the previous owner immediately before he sold it to me. It had piano tops and an e21 head tha. It ran poorly on the way home. I pulled the head and found the pistons all had valve impact marks, despite having had valve recesses machined into them.
williamggruff
  • 1 year later...
Gosh, I apologize for letting this slide, fellow FAQers.
Reassembly went fine with my engine, and there was no interference in the valve train.
During initial dyno tuning, the motor made 127.5 whp and 125.5 ft-lbs
