Tank install finished
Sides in:
Seam sealer covers all sins:
Tanks Inc EFI pump ready to be installed:
Got a 3D printer to make this gas cap adapter:
All done:
Now I just need to run new supply/return lines.
  • Like 4
John Baas
1976 BMW 2002
2001 BMW M5
My Blog!
All done:
Question - am assuming this is a fuel cell and this is a race car?
Just curious, love it over all and nice work.
Cheers,
Jason
Edited by JsnPpp
1973 2002tii (2764167), Baikal, sunroof, A/C, 5spd OD, 3.91 LSD, etc. Rebuild blog here!
--> Blog: Repro tii cold start relay;   --> If you need an Alpina A4 tuning manual, PM me!
Cheers,
Jason
Thanks.  Technically, I think it's just a fuel tank, it doesn't contain any foam.  Also, it's a street car (wannabe race car?)
Overkill?  Probably, but it does have a few advantages, it's bigger (15gal vs stock 12?gal), and it allows me to install the EFI pump in the ideal location (per the instructions, all the way back)
It was also slightly cheaper to buy the metal and make the support for this tank vs. buying a whole new trunk floor since mine was rotted out.
John Baas
1976 BMW 2002
2001 BMW M5
My Blog!
Totally get it - and a fun maker challenge as well! I can absolutely relate.
Thanks for the additional info..
Jason
4 hours ago, uai said:
starting to look more like an engine bay today
What adapter / plug did you use to fit the quick disconnect air lines into the carb? I just have a piece of foam filtering that air right now and would love to connect it into the filtered air source.
'98 M3
'74 2002 Touring
'01 750Il
'96 B3 3.2 Touring
 A little known and much abused fact about  Webers is the float bowl vents on DCOE should be vented to the atmosphere not the filter so they get steady air pressure for the emulsion tubes to meter  not the variable pressure in the filter. Very nice installation using the stock style linkage.
Edited by Son of Marty
George S Patton
A friend just recently had problems getting his mid throttle jetted - after spending hours on the dyno he called VGS who are the importer and most competent resource for Weber within Germany - they recommended having the fuel bowls connected to the Airbox. After he did so the car ran much better under partial throttle.
It's pretty easy to pull the plug when I'm on the dyno, but it would be a lot of hassle getting it set up in a hurry. We'll see once Im on the dyno.
Cheers
Uli
I took one like that 10mm OD carb side cut down to a couple of mm, 6mm tube OD.
To connect to the carb I used some generic rubber plug where I stamped the hole myself
Fabbed up a solution to the spinning stock knob. Welded a tube and threads onto a stock bottom section. No way this will spin now! May or may not need the set nut with the delrin ball knob. Hopefully the replacement 4 speed and the new shift bushings give a more direct feel.c779c5baed8d90c01e15bbebbb5b61a1.jpg
Sent from my SM-J327VPP using Tapatalk
