Weber Retroject Throttle Body - EFi made easy
NickVyse
No, if you read what I wrote above, there doesn't seem to be anything on their website about it.  I did NOT follow Nick's forum link- I'll bet the details are there.
Sounded like it was in development
You will have to do a lot of size engineering to get that to work.  People want to just grab something and run it (seat of the pants stuff).  I've made chips for stuff from 1987 to 1995 GM system, both TBI and port injection versions, NA and blown. The blown 1995 one couldn't pass Colo emissions before but did after I fixed the chip that someone else did a sales job on the owner.  Engine may start but will soon run out of internal self adjustment (BLM learning).
That's what I was figuring, there's no way the parameters from any of the TBI motor's will be close enough to work on the other engines. But would be an interesting endeavour none the less.
-Nathan
EDIT: Double post...
Edited by roadhog0
-Nathan
Yep, I read your posts Toby. Couldn't find it in either of the other links, just hoping that someone could point us to something. I'll bookmark this instead for now and check in on progress.
Btw, in your previous post what does TWM stand for? I'm new to all of this...
1987 Porsche 944 Turbo (sold)
1973 Mintgrun 2002 "Kermit" (sold)
1973 Inka 2002 "Ernie"
1986 VW Vanagon Syncro Weekender "Otto Van Gonzo"
Mmm, sorry.
TWM is TWM induction- they make really pretty things.
www.twminduction.com.
Oh, spliff- they have been absorbed by Borla...
Guys. Just joined the forum and hopefully can answer any questions you have about Retroject.
Its live on the website now, and we will be shipping in 10-14 days.
The concept is that Retroject will directly replace the Weber DGAV/DGAS style carburettor, and in fact it uses the DGAS throttle shafts and gears to guarantee 100% compatibility.
It is the same height as a DGV, and the top has the same stud pattern as well, you can take off a Weber 2bbl and drop Retroject straight on in its place.
Retroject uses 2 x Weber Pico 480cc/m injectors installed within the body, TPS, ATS, IACV and 3 bar Weber fuel pressure regulator all built in, so hook up your electronics and a high pressure supply and you are good to go. The throttle plates are 38mm, and Retroject should be good for up to approx 190-200 bhp.
The website link is here                                               http://www.webcon.co.uk/shopexd.asp?id=15299
and our new swirlpot/fuel pump solution is here          http://www.webcon.co.uk/shopexd.asp?id=15149
Please feel free to ask any questions
Martin
  • 4 years later...
I'm curious to hear about some power figures from someone who's run this on an 02. Anyone out there? Was there a significant power increase over the 32/36 or 38/38?
1975 2002 - US Spec, Taiga Green
Martin
This looks great!
Do you have any rec's on aftermarket ECUs that would work well with the system?
Currently running a 38/38 setup w/ e-choke, and this is intriguing...
Edit...just realized this post was 4 years old.
Edited by Leucadian
Engine bay OCD is a real problem
@02carbs
1 hour ago, Leucadian said:
This looks great!
Call Redline (owns Weber) and ask them. They’ve been super friendly and helpful whenever I’ve called with tech questions.
As I have said before about this. (I haven't checked recently) is that it looks really cool, nice set up etc. But I still haven't seen any posts anywhere (especially here)  touting how awesome this is.
Really can't find any posts that say: Retroject installed and it works great!! Here is my how to, Buy this loom, sensors and ECU and it....
 4 years of silence may mean a lot.
1975 Malaga. It is rusty but runs. Just like me.
4 hours ago, Leucadian said:
This looks great!
No reason Megasquirt couldn’t make this work. Just use the previous builds as an example, but instead of the E30 M10 intake manifold or ITBs, just use the one you have with this bolted to it.
-David
1972 2002 - 2577652 Follow the fun
Pretty real sure Fiat owns both weber and solex. Thats why I don't deal with redline IMHO if they don't know they tend to make up answers.
George S Patton
Yet after a quick (and dirty) search, I cannot find any record of a successful install... no jeep, toyota, opel , ford, etc installs anywhere..
Lots of the same advert with the same link to webcon....
Not exactly a smooth idle going on there... my normally aspirated somewhat tired 2L runs better than that.
Hopefully some tweaking can be done.
Not for me, too buggy still, too many unknowns, not enough(if any) practical applications documented. Hate that the injectors are situated upstream of the throttle butterflies. Better, probably easier options out there.
Says the guy with the donor 85 318i stuffed in his barn.
Edited by tech71
76 2002 Survivor
71 2002 Franzi
85 318i  Doris
