Front Suspension Question
its55
Go to solution Solved by Mike Self,
In rebuilding my front suspension the nuts highlighted in the picture below that I am removing are all castle nuts.  According to RealOEM as well as the shop manual, they're all supposed to be self-locking nuts.  Is this just a case of a past mechanic installing the wrong nuts?  Perhaps he was confused since cotter pins are also there...
Edited by its55
  • Solution
I've done the front suspension on both my '69 and '73--which had never  been messed with 'till I did 😁...and the nuts you circled were in fact castle nuts.  I suspect a PO swapped 'em for nyloc nuts when they couldn't align the cotter pin holes and/or the cotter pins broke off in their holes and they couldn't (or didn't want to take the time) to extract 'em.
I'd definitely use castle nuts and cotter pins.  Do you want to trust your front suspension to a small bit of nylon, or a nice steel (or make it stainless steel for easy future extraction) cotter pin?  And don't forget to torque 'em with the car on the ground...
Don’t wish to be pedantic but the OP is removing castle nuts and states the literature states self locking nuts.
Dont about the US but here in Blighty self locking nuts and nylocs are two different things.
Phil
1975 1602 with an M42 engine.
Project thread http://www.02forum.co.uk/viewtopic.php?f=11&t=14853#p107713
 I believe that's correct anywhere.  "Self locking" nuts do not have nylon, In think the threads do the "locking".
51 minutes ago, PhilC said:
They look like castle nuts in the picture. Why would they specify self locking nuts and show cotter pins. Maybe a mistake in the literature you are using and the past mechanic was correct?
The shop manual also shows self locking nuts.  The RealOEM site picture might look like castle nuts, however the BMW part numbers per the picture are all self locking nuts.  I guess it wouldn't hurt to put cotter pins in front of the self locking nuts, however, I've not seen that done...
Edited by its55
Learn stuff every day...I've always been a little leery of self locking nuts as (1) they use friction to hold themselves in place, thus can wear over time, rust and vibration,  and (2) the deformation on the nuts could gall lor otherwise affect the threads on the bolt.  But I guess they work OK.  or they wouldn't be used.  Still like cotter pins and castle nuts, though.
Since most of my down in the grease experience is with roundies, I didn't know until today that later cars used self-locking nuts vs castle nuts/cotter pins.  Another snippet of information to stash away in my already overcrowded brain...
58 minutes ago, 2002iii said:
I believe the self locking nuts started in 74 with the square taillights.
17 minutes ago, Son of Marty said:
I'll 2nd that 74 and later have self locking nuts, I've never seen one losen up.
I wasn't a 100% positive with the start date or if all the square taillights had them.
Thank you both,
Matt
One thing I hate about those cotter pins is that clothes catch on them and cause scratches whenever I get near.
  • Like 3
  • Haha 1
I've never taken apart a 75 or 76, and have never come across anything but a
castelated (probably technically, crenelated)  nut with a cotter pin.
So it was probably a change sometime in 1974...
