My 1974 02 is getting a new B48…has this been documented??
Noho2002
Many similarities between the B48 and B58 engines.  Here is info on the B58.  There may be a similar document for the B48.
Engine load control is for the most part with the throttle wide open and the valvetronic system controlling the intake valves lift.
B58 Technical Training.pdf
Is that Taiga, Florida?
I just did a Honda AP2 swap and one thing I learned is that you need a lot of room for the radiator and fan. The shark nose really eats up space. Hopefully you won't have to modify the core support and ruin that paint.
Edited by Georges
Thanks Jim,
That technical training manual is awesome!
Consumed two cups of coffee and a good amount of my Sunday morning .... couldn't put it down!!
Is a similar manual available for our 50-year-old M10??  If so, it's probably a very short read. 🙂
John
14 minutes ago, Noho2002 said:
Great read indeed thank you for that. I think also the radiator will have enough space. Only fabrication will be the tranny tunnel
You might find it helpful when figuring out things like the water temperature valve control .
Then you might like this one John, on M Engines History … No M10, though it does cover S14, and there’s a bit o’ M10 in there.
Geek out to some historical engine tech..
(Apologies OP, this is completely OT. )
M Engine History tech.pdf
  • Thanks 2
Where we goin’? … I’ll drive…
5 hours ago, John76 said:
Sheeesh....I'll stick with the M10 in our "Flintstone" cars!
Valve guides cannot be replaced??? Are these modern marvels throw-aways?????
I know some valve guides are sleeved to repair instead of replacing the entire guide.
