Barnfind in my own garage: Bringing a '73 Tii back to life
JsnPpp
37 minutes ago, JsnPpp said:
Three 10mm bolts to remove the fuel pump. They came out easily, but I need to order new ones. Thankfully these are only $26 each. No joke.
If you are talking about the rubber absorber/mounts, here is a great (and MUCH cheaper) alternative (don't let the name fool you, they are small, just like the original ones):
WWW.AUTOHAUSAZ.COM
Find Lemfoerder, 1531301 Radiator Mount; Rubber 17111113699 at discount prices in our extensive BMW auto parts catalog. AutohausAZ offers a large selection of Lemfoerder parts online. 2 per car. Fits BMW 528i, M5, 318i, 320i, 318is, 633CSi, 733i, 318iC. 1531301 W0133-1641482
Karl B.
1974 2002tii Malaga ("Conrad") -->> Conrad's Restoration Blog
2003 330i ZHP 6-spd
2011 328i xDrive
Thank you Karl! This is really great and much appreciated. Wow, those are much more like it!
Edited by JsnPpp
1973 2002tii (2764167), Baikal, sunroof, A/C, 5spd OD, 3.91 LSD, etc. Rebuild blog here!
--> Blog: Repro tii cold start relay;   --> If you need an Alpina A4 tuning manual, PM me!
WWW.AUTOHAUSAZ.COM
And there isn't anything special about the 10mm (M6?) bolts at $26, right?
Ray
They look like just rubber vibration dampers, should be the same, I think. At $4 each it's worth a try.
I'll still probably shell out the $32 each for the three pieces of foam for the gas line though. Doh!
Measured the fuel pump bushing/mounts, they are 15mm
Fuel pump needs cleaning too + new fuel line.
IMG_8663.thumb.jpeg.c0111288cd7da27f219bddd45f2919a5.jpegIMG_8667.thumb.jpeg.b58d552f70e3a6c856f7f507cfc5bf75.jpeg
Here is a shot of the undercarriage. Still has some grease, I'll hit it some more.
Didn't get a chance to work on it this evening. Tomorrow for sure, bushings arrived in the mail today!
  • Like 3
Your new ones should be the exact same measurement. I think the only difference is the threaded studs are a little shorter than on the new bushings.
Karl B.
2003 330i ZHP 6-spd
2011 328i xDrive
Some rear subframe work with weekend. I forgot how much time it takes to remove bolts, clean them and degrease the area. Kept finding new areas with greasy dirt. Caked on greasy dirt. Scrape, wipe, scrub, spray and repeat..
Top of rear spring perch had some surface rust and a bit of pitting. Nothing serious but enough to clean, ospho and topcoat.
Started pressing the new poly bushings in. I had installed poly bushings in 2 decades ago. They were actually crumbly in some areas which surprised me.
So, it's basically the same as it was last week, only cleaner and with bolts/nuts in place, and poly bushings where I can. Hasn't been installed to the body. My plan for the weekend was to have it on wheels already.
I'm a visual person so I made this diagram to help out. Based on the faq torque page. I'll be honest, the descriptions on those pages aren't always easy to align with that I see. So, I took what made sense, added the bolt size. Maybe it helps someone else too.
  • Like 8
Did zero on the car today, unfortunately. Some random shots from weekend.
Cleaning bolts...
Pressing out the semi-trailing arm bushings.
Cleaning differential carrier.
Ospho on the spring perch. I let it sit and keep adding to it for 15min. I then thoroughly wash it off and dry it quickly, often using a leaf blower 😀. Then 1K primer and paint. I'll snap a photo of it with satin black top cover.
I need to move it to high gear. Next steps are reinstall the rear suspension. Need to finish the rear suspension rebuild first, mostly torqueing everything down.
Edited by JsnPpp
51 minutes ago, JsnPpp said:
I need to move it to high gear. Next steps are reinstall the rear suspension. Need to finish the rebuild first, mostly torqueing everything down.
Remember, a lot of that isn't torqued down until the car is on the ground, with a full tank of gas and some fat guys in the front seats.
Karl B.
2003 330i ZHP 6-spd
2011 328i xDrive
With oem rubber true but using urethane bushings it doesn't make a difference.
Solid progress over the last couple of days. More soon!
Edited by JsnPpp
I see you are going to reinstall the rear suspension prior to body and paintwork. Hope the chosen shop protects that/those areas from overspray.  Redoing things isn’t fun.
Good call. I may take it out again when ready for paint.
At the moment I just want to 1. Get it rebuilt 2. Get it out of the way 3. Enable the car to roll around (I'll add the wheel dollys under the tires).
Once it's mobile again (this weekend!) I am hitting engine bay full time.
Still possible to hit my laughably short time frame.
Jason
