M10 Rebuild Project
2002#3
Go to solution Solved by 2002#3,
Quote
"Driven" lube?  It is slightly thick, oil-soluble ass (embly) lube and came with the cam.
If the cam grinder wants you to use it, do.
The entire tube.
On the cam.
Also, a high- ZDDP oil (flat tappet break- in oil) too.
learnt that one the hard way.
M10 Rebuild Part 12
Installed an oil pan baffle for the M10 rebuild.  In case anyone is wondering...(i) the near edge of the baffle is not sitting on the rim of the pan (as it appears) but rather ~1/2" below the rim and (ii) none of the welds distorted the pan.
I await hearing from the machinist re: status of head surfacing and block decking.  Then, hopefully, begin assembly at his shop so he can look over my shoulders and provide well-deserved slapping coordinated with the timing of my errors.
Larry
  • Like 3
  • 1 month later...
M10 Rebuild Part 13
Rebuilt the Weber 32/36 that came with the project engine.  Pretty straight forward; however, rebuilding required more than just a rebuild kit (from alfa1750):  new water choke chamber, power valve, special washers, and other worn do-dads.  Not settled yet on water or manual choke.  When the block and head are finished, I will try, for educational purposes, the 32/36 (with SyncLink) > see how that performs > then a 38/38 > see how that performs > then, maybe, a couple of 40's.  Will be interesting to determine which carb combo plays best with a slightly larger bore (91 mm), 10 CR, custom pistons, 292 cam, little lighter fly wheel, and header.
IMG_5333.thumb.jpeg.3777021b7cd7e6527c56554345cd0367.jpegIMG_5455.thumb.jpeg.8b0eba42570fc8ccd85486c3b333d011.jpegIMG_5466.thumb.jpeg.5f0d61dc56e549483239401da28c6c12.jpegIMG_5467.thumb.jpeg.d3c36ae6be19a5c85fb59dd9d8dfd8cc.jpeg
  • Like 3
  • 5 months later...
M10 Rebuild Part 13
tii Distributor rebuilt by Advanced Distributors has come home.
Machinist has blasted, fluxed, rebored, and bushed the original rods, decked the block, and is starting to grind the head (yep, the cam gear cover is attached).
Edited by 2002#3
3 hours ago, 2002#3 said:
Thanks, Joe.
I will post more as I learn and spend increasingly more of each Social Security check.
Stay tuned.
Larry
Social Security? You don't look a day over 50 Larry. 😉
  • Haha 1
(1973 Fjord Blue 037) Vin 2588314- Build date February 6th, 1973- delivered to Hoffman Motors NYC February 8th.
