rear reflectors
echappe
I can only speak for my '72.
Do not know the answer to the first question.
Yes, the lenses are the same.  But, the housings are different.  The side marker housings have a lamp socket and wire exit with a rubber boot.  The marker housings are solid with rubber gaskets.
Edited by Tsingtao_1903
Illuminated rear side reflectors weren't introduced until (I think) the modell 71 cars in mid-1971, but the rear reflectors were installed beginning sometime in 1970.  The parts book shows a different part number for those base gaskets for the rear reflectors:  63 14 1 353 061 & 062, and they're different part numbers for the gaskets used for the front fender reflectors.  Whether they're still available...check with Blunt.  Chances are pretty good someone on the FAQ has some good used ones that came with damaged for faded reflectors.
Those gaskets all looked the same to me; I was surprised when I checked my parts book and found different numbers.
  • 7 months later...
Bumping this thread.  My reflectors both front and rear quarter are of the type pictured on the right with the wider screw placement.  I for the life of me cannot find these any longer or any information as to what years these were used.  My car is a 69 02.  Does anyone have any thoughts on how to find the new parts or are people drilling a smaller width to use the newer reflector assemblies pictured on the left?  Any comments are appreciated.
Jeff
Jeff
Jeff- let me look at what I have leftover from my 69 tomorrow.
Modifying Vern to have the side marker lights in the rear reflector position, they will be wired to act as additional brake lights.
Andrew Wilson
15 hours ago, Gordon said:
Or you can delete the US spec side marker lights/reflectors for a true Euro spec 02 look. I went this route on my 74 tii.
Comin at you one level up ;-)
I don't take myself or opinions Seriously
My 4th 2002 and the first set of Square Tail-Lights
See the 4 versions of my 2002 project here: SoCal S2002 | Facebook
I think that this a really interesting solution, I would also suggest an additional LED strip on top attached to the upper window gasket since it seems that were programmed to look for the Third Brake Light position for a warning.
Many totaled 02's with slight rear damage
Yup, LED strip already in use.
Andrew Wilson
