Anyone Using The City Light As A Drl?
austinmf
3 watt bulbs and are invisible during the day...and I'd be leery of putting a higher wattage incandescent bulb in the socket due to wire size...but if you can find a (much) brighter LED, that might work.
cheers
Thank you guys! I had city lights in an old scirocco but I cannot remember if they were bright or not... I was going to hard wire relay them in but if they are dim, I will go another route.
FOR SALE-----74 2002tii 2782194 Turkis, Megasquirt, Korman road sport springs, Bilstein HD shocks, 13" FPS Bottle Caps
As mentioned before LED may work if you manage to get a higher what bulb in there and you are up to re-wiring then you got a nice project in hand.
2002 "tii" coupe 1970
E21 320/6 2.7 Stroker 1981
E23 730 1978
City lights are contained inside the Euro headlight housing, not the turn signals. The stock power comes from the turn signals, since they come on with the parking lights. I think...
I have thought about using a colored led for accent lighting at shows, etc. I want one that works on a separate switch. If you find a good LED solution, share with the class.
-David
1972 2002 - 2577652 Follow the fun
  • 4 months later...
I use them every time i drive during the day; saves the h4's. 4 watt bulbs and bosch headlights, not enough to drive with, but easy to see from a distance. Just like Harv's.
how much grinding of the headlight bucket did you need to do?  I think I am going to have to grind enough off to compromise the integrity
Just drive with your low beams on. Bulbs aren't that expensive... I do it in all my rigs and have no issue.
-Nathan
There is some grinding but not that much.
I don't know what the wattage of my city bulbs but they all came from DS Lighting so they must be 6's.
John
1665778
