Early Lower Timing Cover Pointer Hack Needed
Go to solution Solved by Mike Self,
I'm rebuilding an early 1969 M10 and the timing cover that came with it is lacking the pointer (see below).  Has anyone come up with a hack to add a pointer.  I notice the back of the cover has somewhat of a bung, but I'm reluctant to drill through it to add a pointer.  Any thoughts on a solution?
Yep, must be some of those covers floating around.
I have at least two.
Just but one somewhere
Edited by tech71
76 2002 Survivor
71 2002 Franzi
85 318i  Doris
I'm cheap and my cover has already been decked to match the block.  I haven't bought the new flywheel yet so that may be an option.  I new used cover is an option, but....$
Murph
The problem is BMW over the years used several different locations for the timing pointer and you will need a matching pully or at least remark your pully when the engine is at TDC or as above just time it off the flywheel.
George S Patton
With a battery sittin there it’s not that easy to get a clean line of sight on that pin/ pulley anyway
Edited by tech71
76 2002 Survivor
71 2002 Franzi
85 318i  Doris
Battery is in the trunk so that's not an issue, but I do agree getting a line of sight on my current engine that has the pointer is PITA.  I was planning to use the front pointer for when I degree the CAM in addition to my gauge.  Flywheel may be the best way to go or just rely on my wire I'm using to set TDC.
Thanks
Murph
I've always made a pointer that hangs off one of the unused mounting bosses and indicates TDC
of whatever front crank pulley I'm using.  Or whatever degree marking that's the most useful.
I seem to remember a piece of aluminum angle can be cut to work, but this was all done before your
RFID tracker was also your camera, so I'll have to go take a picture of it tomorrow.
  • Solution
Per your first picture:  if the pointer goes into the blind hole at the 5 o'clock position relative to the crankshaft hole (and connected by a rib), I'll wager that's a 6mm hole.  It would be easy enough to tap the hole for a 6x1 mm thread, then take a bolt or machine screw of appropriate length, cut the head off and grind the end to a point (chuck it into an electric drill and go after it with a file).  Thread it into the hole with some locktite and your problem is solved.
Threading is probably a better solution than trying to press a rod into the hole, as too much pressure might split your casting.
