Kugelfischer racing injection with slide throttle
inca-orange
12 hours ago, markmac said:
.I am sure your an expert in 'atomization
I resemble that comment (maybe more than you intended).
The slide valve is more for a linear flow area change rate with a given percentage of slide movement than it is for flow path obstruction.  A butterfly valve does not have this linear relationship.  BMW attempts to avert this non-linear relationship with the linkeage on throttle bodies like seen at the top of the 325 and on the S14 throttle bodies.
Edited by jimk
My set-up is with 292 camshaft, Alpina A4 kufi pump, injectors with 40+ bar pressure a special interface (gear) between kufi pump and slide throttlebody. The city is no race track, so limmitation of power is needed I believe.
Sent from my Redmi Note 4 using Tapatalk
Concept of slide throttle is relativly easy. When slide throttle is open no barrier of throttle blades like on a butterfly system.
What needs to be done on the race track? Full throttle!
That's true, and what I have done is made a special gear to have ca lambda 0,95 in compleet rpm area. Gear based on modified Tii mechanism.
  • 1 month later...
On 12/2/2018 at 11:13 PM, Driv3r said:
Rama RHD in Australia makes all sort of custom ITB kits for BMW’s. His work is flawless. He’s also done an ITB kit for fuel injected M10. Here is one of his kits for M20
Wow, how much are they are where is he !!!!!
I love the look of itb,s . 4-5k fully kitted is a lot. I thought about it. Maybe the next build.
If I were to do it, Halltech would be the call for the controller. Lot of inputs and good post sales support. Bosch fuel pump and you are good to go.
"Goosed" 1975 BMW 2002
