sometimes its the things you cant see
stone02
Hi,
   so some times it is the things you can't see.
like working in the dark or in an area that only has one light.
  anyway this car sat for a long time as the owner has
many cars and this 72 tii was giving  him problems. so one
night i went and helped him try and move it, the drums are
stuck. then one nite we try and fire it up and the clutch
is stuck to the flywheel. then he tries to diagnose and
replace the distributor and the rear fuel pump. finally
i get another shot in the actual dark and decide that
the KF is not working.
   tonight i go over and the car is inside a well lit shop
so i am preparing to remove the KF.  by chance i decided
to time the motor (TDC) so the work will be easier.
thru the crack between the upper belt cover and the front
timing cover i can see the belt does not turn when i rotate
the motor. IMG_0275.JPGIMG_0276.JPGIMG_0277.JPGthis is what i found, the pump belt,
after about 40 minutes of parts removal and making one new special tool.
so, two hours more scraping and cleaning ever tooth on the crankshaft and
the KF pulley and the car springs to life immediately when the key is
turned. fuel air spark, those are the three but again it some times
is the things you can't see. next trip to the car is to put it back together
and free up the clutch and release the brakes.
stone
stone racing co
phila pa 19123
That's gotta be the worst belt of any type I've ever seen; can't decide if it just melted, or was chewed by rodents...maybe both!
Good catch--and you saved yourself a LOT of work!
That's the worst one I've seen. I replace mine every 30K.
Edited by adawil2002
Andrew Wilson
