My 2002 diagnostic tool demo (wunderbox)
PatAllen
I would so buy this if only I knew my wires are correct. I might check the harness manually and see if is ok then I may order one!
The way I see it you'll be selling quite a bit of these fancy machines.
i am a victim ;)
if its for your 320/6 you must be aware that the tach output is calculated for a 4 cyl. engine so the readout will be off quite a bit.
i can potentialy make you a special one for a 6 cyl motor (different amount of pulses per revolution).
1985 XR4TI, 22psi ±300hp
  • Replies 60
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
I hope you make more because I am very interested and saw your post a few weeks ago but just saw this today. Let me know how much and when!! Thanks Pat.
73 colorado orange 2002 in restoration
owned for 30years
71 2002 gone to parts heaven
72 2002 Malaga Sisters
05 Mini S Moms
FAQ member # 31
slowly but surely...
most of the 16 boards are assembled. i need to make the cut-out into the enclosures and wire them in.
As i received a lot of e-mails and some questions, i decided to add some more functionnalities:
-selectable tach mode, 4-6-8 cylinder (default is 4 of course)
-oxygen sensor mode: off, narrow band, wide band (default is off).
Wide band mode is still just a display, mostly adapted for like the Innovate motorsport (and some others)
0v=10afr
5v=20afr
selection/program changes are made with a jumper inside the unit and saved into eeprom memory, ie, the unit will remember your setting if its changed.
That was just software after all...its free.
Mmmmmm I haven't had a Moosehead in years!
0v=10afr
5v=20afr
Scott B.
1969 2002, 1972 2002, 1967 1600, 2001 540It
That's going to be great. My '74 3.0 csi has the same diagnostic port.
That demonstration video was very well done too.
Thanks Pat!
'73tii Inka 🍊
'74tii Fjord 🏄‍♂️
Wow that is pretty cool. Let me also put my name in for one if you decide to do another run. I read the original thread but just noticed this one and didn't know you were making more than one.
From the response here, it sounds like you could sell out another run.
- Cris 70 Euro 02 - resto pages
Alpine Motorsports
http://alpinemotorsports.blogspot.com/
