My 2002 diagnostic tool demo (wunderbox)
PatAllen
Tuned up cxzsaq's tii today using the wunderbox.
It makes tuning a breeze.
You have full control over the start / run / rpm. Especially good when trying to dial in both timing and mixture on a motor.
No need for a old analog rpm gauge that you have to connect to the coil.
FYI, dwell was reading ~52 degree with a pertronix ignitior. This was with a (from advanced distributors) rebuilt 008/002 mechanical advance distributor.
Good job Pat for a fantastic product.
i am glad my tool can make other car run better or at their best. that was the goal i guess ;)
imagine now if you would have an 02 sensor, even a narrow band would be helpfull...
cheers !!
1985 XR4TI, 22psi ±300hp
  • Replies 60
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Does this product work with a WB O2 sensor? Or only with narrow band?
Thx!
Byas
it can read the signal from the controler of most wide band unit as long as it is 0-5v
0v=10 afr
5v=20 afr
or AFR= (v*2)+10
otherwise it can read any narrow band sensor.
you can change the 02 sensor parameter/type inside the tune box with a jumper. default setting is off.
cheers !!
We had a wideband gauge in an unfinished car, we taped the gauge to the rear view mirror!
A wideband O2 is the only way to go for tuning a tii.
On my own car I'll probably get that extra pin in place for the wideband, so I can read it directly off the unit.
-Justin
Second run toped off.
i collected way more request/names than anticipated so i temporarily disabled my e-mail button.
Will probably call for a 3rd run in few months as i am gathering enought pars to make 50 more pcs.
thanks for this much unexpected interest.
will follow up often on the project. i will add some more goodies to my "'line of products" soon as i see some potential there.
-stealth tiny LED A/F meters (wb or nb)
-cheap wide band kit (!!!)
-cheap narrow band kit
cheers !
cheers !
What a coincidence that the same day I hear about your tool, you stop making them. I am VERY interested for the next batch.
Great Job!
What is the total price on one of these so i can start putting some money away for one. I am going to get in on this third batch no doubt.
73 colorado orange 2002 in restoration
owned for 30years
71 2002 gone to parts heaven
72 2002 Malaga Sisters
05 Mini S Moms
FAQ member # 31
  • 2 months later...
cheers !!
Thank you both! Pat for making the box! Justin - HUGE thanks to you my man! Car runs better and better every time i run it!!!!!!!!!!!!!!!!!!!!!!!!! Engine compartment is almost there.
  • 3 months later...
Hi
i am in Sherbrooke.
Local pick-up is certainly possible, but i dont have any assembled at this moment.
I plan to start another batch this fall, soon.
I keep record of all the request and process them by priority of arrival.
Mr. in south africa, i have your name on my list and you will get contacted soon.
Thanks again for all this.
Hi Pat,
Can you put me down for one too (especially now I have gone back to points). Do you want me to email you off the board with my details etc?
Simeon
rtheriaque wrote:
