2002ti wannabe project begins
jgerock
Jim,
first of all I`d like to agree to the comments posted before: Your car definitely looks great!!!
Then I´m sorry that I didn´t make it to write this post earlier. Don´t have that much spare time at the moment and that one single day I had a short look on the FAQ website after the easter days the recent update seemed to not be complete and I couldn´t see any pictures, links were not working and so I logged out again after a minute or so.
I´d like to apologize for my wrongly drilled bracket. We´re all human and so we make mistakes - seems like I made one also when I drilled your bracket. Very sorry for that.
Thumbs up for your first test drive on the road!
Best regards, Lars.
Ei guude wie? (Spoken as "I gooooda weee" and hessian idiom for "Hi, how are you?")
Já nevím, možná zítra.
Visited the DMV for tags and registration Friday afternoon.  Installed both front and rear tags (front one using the stock "spreader" bracket)
For the rear, I was going to use my used European aluminum mount but decided it didn't look right so I drilled (2) holes in the panel and reinstalled the (2) chrome plugs from the
original 69 tail panel.
3DA32287-540C-4CC7-9A94-6F7833755616_zps
To help prevent rubbing the aluminum plate against the body, I cut up an old side marker gasket for the bolts and glued an old tag lamp
gasket to the back of the plate.
081B08D9-952D-488B-9386-369B3A0828C0_zps
Installed a VDO oil pressure gauge in the center console and partially wired it to power and ground.  Still have to install the adaptor block and sending unit.
AB0BDC7B-5B6F-4B70-876C-F19C4BA82C06_zps
Tackled the old nasty trunk boards today by removing the original vinyl (tons of staples), cleaned up the wood boards then added new vinyl I found today at Hancock Fabrics.  I was hoping to find a lighter shade of gray but Hancock is going out of business so everything was 25-30% off.  I purchased 2.5 SQ yards of a Gull Grey marine vinyl @ $ 14.99/SQ yard.  I will add the (3) forward pieces tomorrow.
CDC7F325-0BBB-4F5B-9EA3-C583B7AE4B82_zps
546FF351-BA11-45E8-96A0-A91DBCDF48ED_zps
Comparison between the new (Gull Grey) vinyl next to the original lighter vinyl
AF92E49A-4F07-4F88-A99B-09B5599F5E7D_zps
I used carpet adhesive on the edges and 1/4" staples in a very old Arrow brand staple gun my father gave to me.
EDE35ED6-9327-4077-9D82-545FFFB64470_zps
DEDAB067-62E0-4A42-89FC-933F1F5B3B22_zps
Edited by jgerock
Finished up the vinyl for the trunk this morning.  Not show quality since the fuel pump wiring and new fuel line interfere with the right side piece.  I thought both pieces were identical but after I cut the left one and flipped it over for comparing the right side, the right was longer by a few inches (using the old glue remnants as a guide).  I still haven't secured the RS board to the center partition.
AB09D76E-8B91-4394-A155-0C29943B5296_zps
Borrowed some ramps from Marshall today and torqued the front and rear suspension pieces.  Didn't realize how difficult it is to torque large hardware with only a few inches of room below the car.
My assortment of tools used on the front end (including the tie rods, ball joints, center track rod, radius arms, control arms and sway bar end links).
5D382A07-3020-49DB-9CEF-E66DB78E26FE_zps
While under the front, I checked the exhaust manifold nuts and they needed tightening.
8D6BF3DC-4F64-40AF-8532-A4D3AD202A9D_zps
8FE669E4-C1AE-47EA-B1DB-70A70D3A5954_zps
Rear trailing arm bolts were torqued while up on the ramps. The outer bolt head/nut is tough to access.  Doing this on a lift would be ideal.
26BFB874-1C10-472C-B792-8DF183E53856_zps
F9468771-8604-4D24-8590-F4239ACCE383_zps
Checked the alternator situation since my dash cluster charge light isn't working.  Car not running battery voltage is about  12.6 Volts.
Here it is while running at about 1500 rpm.
A10AD9D5-32B4-4C03-B374-2AA679552B45_zps
Took the car for a short drive around the neighborhood then tried more carb tuning.  Needs more love.
11B2CFC0-13BE-4161-837F-D44BC5D62B1F_zps
F0C677A4-0738-490E-A625-76E2ECFBB409_zps
For some strange reason, the upper section of both footwells are lacking in the carpet reach up to the cardboard panels. Carpet came from a 74tii so I wonder if there is another difference.
E-brake cables need to be tightened. Front seats feel like really old seats even after I've messed with them twice.
690A90D0-55DC-4ABD-901E-1C4CF6CFD4EA_zps
Confirmed hotel reservations for Vintage in Asheville next month.  Really looking forward to going to this new location.
Edited by jgerock
Visited Pep Boys yesterday hoping to find some wide "chrome" adhesive tape for doing the driver's side door panel aluminum trim.  They only had 1/4" wide tape.
Maybe Marc Caden will have some leftover material (mylar)...
I have four packages of this (about 6"x11" each).  Would that work for you?
Edited by MatthewCervi
Added picture
Matthew Cervi
'71 Bavaria
'18 M2
The Mylar from Aardvarc looks the part but after 2 weeks wants to flatten out and not stick to the tight radius of the plastic trim. I bought roll of aluminum tape for $8 at Lowe's but didn't use it because even polishing it with my multi metal polish didn't get it shiny enough. I found pressure adhesive stainless steel tape but it has writing on it.
Andrew Wilson
Got them sync'd, right?
... where's your ignition timing set?  :ph34r:
Ed
'69 Granada... long, long ago
'71 Manila..such a great car
'67 Granada 2000CS...way cool
Ed
Working on the carb sync. Ed.  Glad I have the wideband gauge to see what happens each time I make a change.
Timing is about 30 degrees BTDC but I have trouble keeping the timing gun cables off the hot exhaust manifold.
