2002ti wannabe project begins
jgerock
Some good progress last weekend...
With assistance from Marshall, we cut off one tab from an old ti linkage and welded it onto my NK linkage
B5E5E916-3117-4FCF-B9A4-A9BC5727BA00_zps
I did have to grind the tab for the choke idle to clear the newly grafted arm but it works quite well.
Installed (again) using my old tii linkage arm
FEAAEA7E-DEA1-4C39-8E65-637A19F22944_zps
Firewall pivot components
0C43FACB-1459-460F-9E3E-E61FF79B770E_zps
Here is the inertia fuel pump cutoff switch purchased from Pegasus. Still have more wiring to do.
358AACF8-82DE-4527-866B-8B79ED2AAAD9_zps
As mentioned above, I was having some electrical gremlins with just battery power.  I swapped the wires at the sending unit so that fixed the signal to the dash gauge.  Marshall assisted me last Saturday and we checked continuity on lots of wires - especially the ones I added for relocating the battery to the cabin.  Turns out the brand new ignition switch was bad (YES - RAY KOKE CALLED IT).  I knew something was wrong last week when I was turning the key from the first to 2nd position - the fuel gauge and oil pressure light were wonky.
1BA17D3E-B92F-45FF-A18D-A01FF7E6793A_zps
Here is the old 69 switch (Bosch brand) next to the brand new one (SWF brand)
6B727AA4-0A58-4FF5-8F60-D6E4C9FA3F3E_zps
So - now the fuel gauge works, and the lights are good.
The rear lights that were on all the time (with battery power) were the brake lights.  Marshall and I adjusted the switch and now they work as they are supposed to.
Filling the radiator with coolant revealed a minor leak at the water pump x bypass pipe.  I used a 1" diameter heater hose and some wide clamps but there was a drip so I changed the front clamp to a BMW one.
99348528-9E06-4B7B-8DE2-197030B51C4E_zps
New AGM battery arrived today from Battery Mart in Winchester, VA.
More after this weekend.
Heh. I'm 3 for 92 now ;-) I've never had to replace an ignition switch. Yet.
Seems like you could find a plastic grommet for that firewall spring hole.
After the update I'm now getting notifications for new posts in your blog. That hasn't happened for quite some time. Guess you better set me back to "ignore" again :D
Cheers,
Ray
IT LIVES!!!!!
Jim has been hammering away at all the details to connect all the wires.  i stopped by this afternoon to see how it was going. just in time to see it turn over under starter and get oil pressure. then we put some spark plugs in it, added plug wires, snugged the alternator belt, pressured up the fuel system, and.....
turned the key............it started almost immediately!!!!!  WHOOO HOOOO!!!!
(pardon the bad cell phone video...started seconds after it caught.)
Edited by mlytle
2xM3
Congratulations, that's a huge milestone! Looks like you'll make The Vintage with plenty of time to spare.
Andrew Wilson
I'm almost speechless.  Think Marshall summed it up with WHOO -HOO.
Backing up a little.  Had to buy some 4 GA flexible cable (from West Marine in Woodbridge) to make the positive starter and engine ground cables.
11EC5559-CD00-48AC-8F9E-920A4DBC992C_zps
After buying some 1/8" x 1.125" steel angle from Lowe's yesterday, Marshall let me (try) and operate his mitre saw to cut the battery box pieces, then he welded them.
D7F3A0F0-9CEC-41AD-B9FB-452496FF80B7_zps
Painted this morning
53137FA3-0E83-4C6F-9BF7-1778124D244F_zps
Installed under back seat
7C3E1AAC-7C55-47DF-962E-A6E36BCF7670_zps
Covered the center console gauge panel (made by Marshall) with the same grained vinyl I used on the A pillar.
628BC3C4-512D-4DEE-8F77-AD27AD576DD0_zps
AEM analog A/F gauge installed in the left hole - right has predrilled hole for an oil pressure gauge
DCD8C276-1BF8-49C1-A485-1AD93A276A3A_zps
B4B12B19-1249-4BE4-B5FB-978245F79572_zps
Distributor is still on TDC for # 1 and the idle mixture screws on the Solex carbs are 1.5 turns out.
AA0A8FB6-EAAA-497C-A0F8-5390232F9944_zps
Car is running very rich (10 on the WB sensor) and I had a leaking valve cover gasket so I have some tuning to do..
Edited by jgerock
Jim.. I let you down as far as the linkage parts; I was supposed to send you some and life got in the way...  I'm happy to see that Marshall was able to provide the welding skills and get your linkage sorted out.
As for your rich-running... give it more ignition advance. My Solex DDHs gave me rich-running symptoms until I advanced the timing to the Haynes Ti specs... page 67 in the manual shows 28-32 degrees at 2000 rpm. ...depending on your compression ratio, of course.  I have flat tops and ran 32 degrees at 2000 rpm with an IE dizzy, until I installed a 123Ignition.  I programmed about 32 degrees at 2000 rpm in my 123 curve.  It's easy for me to double check with a timing light that I'm where I need to be.
The car looks amazing, by the way.  Beautiful work, indeed.
Ed
Here's the BMW Ti glovebox manual spec on ignition FWIW.
Ti ignition specs.pdf
'69 Granada... long, long ago
'71 Manila..such a great car
'67 Granada 2000CS...way cool
Did a few things today while it snowed and the wind blowed outside.
Roundel installed
2261F803-A8F4-422F-AF3F-99F6961CBB32_zps
ti emblem installed
31C4DC6A-84C3-47D9-8364-C13BDFC4A7C4_zps
Put the Ronal wheels on the car and was going to settle the suspension by rolling the car back and forth but the LR wheel was locked.
Called Marshall after remembering I had installed the spacer in the wrong position in the trailing arm.  I must have only corrected the right side.
Pulled  the axle/CV out along with the bearings and found the spacer next to the inner bearing (should be next to the outer bearing).
Will put back together correctly in the morning.
3C4181F1-21FF-43CB-8B50-E666274AB7FE_zps
Had a nice visit this morning from Daron.  Good 2002 discussions as always.
Corrected the LR wheel bearing this morning then decided to roll the car outside (under it's own power).  Fumes from the exhaust coating were pretty strong plus I still had a valve cover leak. Turns out the stupid acorn nuts that were originally on the 72tii engine were bottoming out even with a wave washer so I replaced them with standard hex nuts.  As the car warmed up, I noticed the heater hoses weren't (helps if you turn on the heat) and I had a leak on the brass plug at the manifold junction.   Replaced the brass plug with another old temp. switch for now.  Car still was running way too rich and idling no less than 2,000 rpm so I pulled it back into the garage.  Well at least I know reverse and 1st gear work.
Put the front back up on stands, added some coolant (it was low) then tried burping the lower hose with my hand.  Pulled out the Blue book and read my baseline mixture was wrong.  Should have started with 1/2 turn out from bottom on the (4) mixture idle screws.  I started with 1.5 turns.  Also, the linkage was binding at the firewall so I drilled out the delrin bushing for more play.  When I reassembled the firewall bracket, the vertical linkage rod from the pedal box was too high  even though I had tightened the bolt at the pedal box.  I readjusted the pedal linkage and thought that was my issue.
Started the car back up and idle mixture is between 14-15 on the AF gauge but the car will not idle below 2000 rpm.   Checked the timing with my adjustable Craftsman light and was just a little off.  It is currently set at 23 degrees BTDC at 2,100 RPM.  When I tried setting the idle rpm on the carbs based on the Blue book instructions (car not running) there is something not right between the main (front) carb and rear carb linkage.  More investigation required.
Had ordered a VDO oil pressure gauge from eGauges earlier this week but something is not in stock so I'm not sure when I'll get it.
C1659EDC-F6FE-4757-832F-53DF37E660A2_zps
8E95DE5E-B4E8-4376-97DA-0F8A30EAB7F9_zps
B7FADD51-B100-4964-B11C-29C27D29F77C_zps
5A82A63D-2114-4CAB-BC14-5A2D4B14CDB8_zps
9C5D82C7-A85B-4FE3-A0D6-D3E6E7B3C9B6_zps
The way I wired the A/F gauge, the last reading stays on it when power is removed. Easy way to remember how it was last running.  When power turns back on, the gauge re-sets.
133E53C3-A35D-4B2A-9726-763A36479C85_zps
The car looks spectacular in the sun. It will be a real pleasure to see it at The Vintage.
Andrew Wilson
