Different ac option!
I have posted recently of having the AC bug while my car is apart for paint. This one appears to be small enough to maybe not even need to modify the tunnel and heat and ac and vents on front for center console. I refuse to put my heater box back after rebuilding in the past so heat/ac combo is for me. I did a test fit using their dimensions and it look like a winner. Narrow and short! Thoughts? They make a cable operated plenum too to move the air around. Check it out. Seems a better fit than a Hurricane.
WWW.CARBUILDER.COM
INSTALLATION GUIDE IN THE CATALOGUETo download click on 'Catalogue' above
I've thought about this in the past, too, as the stock heater box is so fragile.  And not a fantastic solution even
when it works perfectly.
The challenge I see with that one is intake:  it may be difficult to get it to draw fresh air from the stock hole.
It'd be nice to be able to duct its intake, so you could switch to recirc mode, or 'mix' mode, at will.
edit- I followed the bunny, and found this:
WWW.EBAY.COM
A lightweight centrifugal fan is used to blow air through the combined heater & air conditioning core and expel it through 2x 55mm (2.17") outlet nozzles. 12v Compact Heating & Air Conditioning Unit 2x 55mm Outlets.
which is even tinier!
Edited by TobyB
now with many mini bunnies
Down the rabbit hole we go!  Perhaps made by Kalori...
WWW.WIDNI.FI
Eberspächer Kalori is a well-known manufacturer of high-quality air conditioner whose product range offers solutions for buses and camper vans, special-purpose vehicles, work machinery and boats.
Ray
I bought a Southern Air Mini Kool which is the smallest modern AC made. It fit fine between ignition and glove box but in the end I didn't use it since I didn't want to build a custom console around it. I still have it if any body wants to try it.
https://www.southernrods.com/southern-air-mini-kooler-under-dash-a-c-only-unit-only.html
Edited by Stevenc22
So with all of these all in one systems, they are designed to work with no outside source of air.
My bright idea for inside for this one is to make a heater box hole cover that will have a cheap cable controlled fresh air vent in it and also pass the heater and ac hoses through it. Something I can make on the bench and the just bolt and seal up using the existing heater block mounting studs. Might be pretty clean!
WWW.WIDNI.FI
Ac for Ambulance and vans…
sure…why not?! 😂😂
I’m totally planning to use this, cooler and AC all-in-one. Runs off a battery or car charger. On hot days put it in the backseat and call it good. It won’t keep me frosty in the summer, but tolerable and I can keep my car stock.
WWW.ICYBREEZE.COM
Beat the heat wherever you are with the IcyBreeze portable air conditioner. It's an ice cooler and...
1973 2002tii Taiga
1969 2002 Chamonix
WWW.ICYBREEZE.COM
That will do something I’m sure but may not help much in a humid Texas car for me.
I had to butcher the dash up, but I put in one that blows twice as much CFM‘s and actually cools the car…
IMG_9070.thumb.jpeg.1f357ec147f598b4fc091cffefe4a74f.jpegIMG_9069.thumb.jpeg.443f9f40c7d71537f61e4bc742b8910b.jpegIMG_9065.thumb.jpeg.791a30dd4df37dee07f4316a5ea77e03.jpeg
  • Like 4
make nothing happen…
I can testify to this… you could hang meat in Barney’s Turkis car
  • Haha 1
'69 Granada... long, long ago
'71 Manila..such a great car
'67 Granada 2000CS...way cool
Well done, Barney!
Ha!
Barney, when you hit the a/c button, does your top speed drop to 67?
Quote
I'd add a fan, too- but that's NOT a bad idea.  Maybe duct that outside air such that it gets easily sucked into the fans on the universal
box- that way, if you want to let cold fresh air in, it'll get (mostly) heated before it hits your legs.  That'd also help
with moisture control, as cool, wet air on the inside of the windshield causes problems.
Eberspacher has been in the heating and cooling business a long time- the aircooled VWs for cold climates got
gas- fuelled heaters, and I've also found their stuff in early EV attempts by GM, Mazda and others.  Everything I've run
across by them has been very well designed, and while the ducting isn't always OEM, the plumbing and combustion systems
look like aircooled airplane parts.  Very tidy.
really regrets selling the '65 notch parts car
  • Haha 1
And it appears to be (the one @Highnote1 linked) a Kalori "SUPER K KOMBI."
Apparently the retail pricing is a closely guarded secret, more or less.
Ray
Looks like just the opposite - if he cracks the rear windows, the jet engine under the dash will give him an extra 20mph on the top end!
  • Haha 2
Colorado '71 2002
'17 VW GTI Sport
