Sloppy and loose shifter
Merry Christmas all,
Can anyone recommend a particular shifter refresh kit to address all the shifter play in my '75 2002? Is it fairly straight forward job? Does the exhaust mid pipe need to be removed for access? A quick search suggested multiple kits and diy hacks leaving me uncertain how to proceed.
Thanks in advance.
First thing to do is determine which style of shift linkage you have, there are two.
While your 75 was probably fitted with the later style there's no guarantee thats what's in there 40+ years later. Need to do a visual on the shift rod to shift lever interface to determine this.. from under the car.
Second thing to do is determine if your shift platform( supports the shift lever) is secure, the mounts that secure it to the trans deteriorate over time and can cause it to have tons of slop.
Sometimes the bolts securing it to the trans will loosen up, maybe even fall out.
Pull the boot up inside the car, wiggle the shifter around and see if platform holding it is sloppy.
Determining these narrows down available options and ensures you order the right stuff.
Merry Christmas to you too
Edited by tech71
76 2002 Survivor
71 2002 Franzi
85 318i  Doris
In a lot of cases excessive shifter slop is caused by the two upper allen head bolts securing the shifter platform to the trans have become loose, as tech71 noted. More prevalent on the right side. I had that bolt disappear into the road valhalla. Check the platform, then look at linkage/bushings etc if not corrected by tightening the major fasteners.
"Sometimes it's a little better to travel than to arrive”  Robert M. Pirsig
As tech71 alluded to I assume the platform is checked by looking under the shifter boot?
No, it's only visible from under the car...the exhaust isn't in the way so much, but the prop and donut are... It could be either the two 8mm head(?) Allen bolts are loose or the rubber-centred brackets the bolts secure have turned to mush (replace).
The other thing to replace are the two 'top hat' nylon washers at the bottom of the shift lever.
You can  check platform for excessive  play from the top.
Pull the boot , shift thru gears, watch platform, excessive movement indicates  worn mounts or loose missing bolts.
Any repairs are done from under the car.
That only applies to the early duel shear style shift rods and fancy smancy after market short shift set ups.
Bushings on later style are completely different and not available individually. You have to buy new lowershift lever and fwd joint.
Thats where some of the hacks come in, couple of bronze bushings from  Ace, some epoxy and  a 10mm ream are alot cheaper.
OP, get under your car and identify what you have, show us, then we can advise.
Edited by tech71
76 2002 Survivor
71 2002 Franzi
85 318i  Doris
IMO, call Blunt tech and they will fix you up with everything you need, get the bushings and mounts and do it all, do it once and move on. Also use loc-tite on the Allen head bolts that hold the shift blocks to the trans case.
  • Like 3
George S Patton
Without  a lift? No not really, you’re working around the driveshaft and guibo. The  fwd joint connecting shift rod to trans shift shaft can be particularly problematic😁
It’s a pain in the rear, access is limited, it’s doable however,, for a first timer/ someone with limited mechanical experience lying on their back under the car, the learning curve can be quite steep.
Doesn’t help that in many cases the area is covered in years of congealed oil. Had to dig it out of the Allen bolts on Survivor. Oh and it helps to have a really long 3/8 in extension, not as good but works is several short ones cobbled into a Frankenextension😉
No
Edited by tech71
76 2002 Survivor
71 2002 Franzi
85 318i  Doris
  • 1 month later...
I'd recommend shopping at Blunttech.com, so you can joint the fun in this thread.
https://www.bmw2002faq.com/forums/topic/334974-shoutout-to-blunttech/
The Blunt kit does not include the gear shift rod joint and they get sloppy, so add a joint/pin/foam insert to the list.
25117503525
The part numbers can be pulled off of this RealOem diagram.
Shift lever
No. Description Supp. Qty  From   Up To  Part Number Price   Notes
01 Set circlip 10 8,0 3 03/1974   07509064295     ENDED
01 Circlip 8,0 3 03/1974   07119932863 $0.11
02 Shim 16X10,2X0,65 2 03/1974   25111220199 $0.30
03 Gearshift rod joint   1 03/1974   25111205070     ENDED
03 Gearshift rod joint SCHWARZ 1 03/1974   25117503525 $37.51
  only in conjunction with
-- Straight selector rod L=151MM 1 03/1974   25111206888 $27.51
-- Shim 16X10,2X0,65 4 03/1974   25111220199 $0.30
-- Shift lever-lower part   1 03/1974   25111220213 $23.00
04 Dowel pin   1 03/1974   23411466134 $0.70
05 Tension bush   1 03/1974   25111203682 $1.18
06 Plastic washer   1 03/1974   25111434194 $0.85
07 Straight selector rod   1 03/1974   25111204357 $37.53
  For vehicles with
5-speed sports gearbox
=Yes
07 Straight selector rod   1 03/1974   25111204359 $92.48
08 Shifting arm   1 03/1974   25111203776     ENDED
  For vehicles with
=Yes
08 Shifting arm   1 03/1974   25111204147 $46.76   ENDED
09 Lock Ring   1 03/1974   23411466112 $0.68
10 Shift lever-lower part   1 03/1974   25111205870 $64.36
11 Shift lever-upper part   1 08/1973 07/1976 25111220778 $91.80
11 Shift lever-upper part   1 03/1974   25111220778 $91.80
12 Cap   1 03/1974   25111205441 $1.52
13 Circlip 10-ZNS3 1 03/1974   07119904911 $0.27
14 Rubber Ring   1 03/1974   23411666133 $1.77
15 Washer 14X25X2-ZNS3 1 03/1974   34301163613 $0.83
16 Spring washer   1 03/1974   23411666122 $1.75
17 Spacer sleeve   1 03/1974   23411200844 $2.27
18 Compression spring   1 03/1974   23411200845 $1.33
19 Ball Cup upper   2 03/1974   23411466110 $8.01
20 Washer   X 03/1974   23411466125 $1.02
20 Washer   X 03/1974   23411466126 $0.84
20 Washer   X 03/1974   23411466127 $0.80   ENDED
21 Shift lever   1 08/1973 07/1976 25111204381     ENDED
21 Shift lever   1 03/1974   25111220214     ENDED
Notes
Here's part number six in the diagram.
WWW.BLUNTTECH.COM
PLASTIC WASHER
I'd also replace the shift rod seal while you're in there.
WWW.BLUNTTECH.COM
shift shaft seal 1 per car
Man. Trans Shift Linkage Seal
WWW.REALOEM.COM
BMW parts 1502-2002tii 2002 Diagram Selection
