Transmission drain
RJT79
It uses an Allen head drain plug--I looked but can't find the size of the Allen key needed.  I want to say 10mm but that may not be correct.
Before removing the drain plug, make sure you can remove the filler plug!  You'd feel pretty dumb with a drained tranny and no way to fill with new fluid!
It's 17mm, or 11/16" will do.  Here's a neat old VW wrench I found at the habitat store a while back.
I've got a big 11/16" Allen wrench that has been getting shorter over the years, as I've cut pieces off to use with a socket, or a wrench for the fill plug.
Tom
  • Like 3
1 hour ago, RJT79 said:
if the plug is the right size, how does it start leaking?
Steel plug and aluminum threads:  different wear rates, different expansion rates.  Folks in the past have used Teflon plumbers tape around the threads; that seems to work presuming the threads themselves aren't damaged.
And there may supposed to be a copper crush washer under the drain plug.  It's been awhile since I had one out, but I know the oil drain plug has one...
15 hours ago, RJT79 said:
 Am I missing the plug completely?
If that was the case your gearbox would have let you know by now.
Fist thing to do is check and see if the plug is loose/ needs tightening
76 2002 Survivor
71 2002 Franzi
85 318i  Doris
Don't go berzerk with the teflon and the tightening-
it's a taper thread, and lubed with the long- chain polymers,
it can split the case.
It's rather likely that it's leaking higher up, and you're just seeing the
end of the trail.  The plugs do sometimes leak, but you'll need to jack the car
crawl under it and really check things like the shift rod seal, platform bolts, etc
to confirm it's the plug.
And then yeah, a few wraps of teflon and an EASY tighten usually does the deal.
Yep! Bloody thing…. Got mine undone fortunately, but I will never make that school boy error again🙄
