V8 into 2002
jmiller
I was given an E21, and I'm thinking it might make a good place to stick an N52.
There's quite a bit more room under the tunnel, and between the radiator and the firewall.
Unfortunately, job one is to redesign the front tension arm mounts...  and then fix the strut angle.
The old design carb engines Chevy V8 is 90 degrees wide  and the Ford is at 60 allowing more room between the inner strut fenders. Have seen these swaps in  internet photos only. Wonder how much room to remove exhaust manifolds or change spark plugs. The Ford probably is longer because of the timing chain water pump housing  means less clearance for radiator. Ford front mounted Dist. is an advantage.  Each company make a V6 same degrees benefit of 1 cylinder shorter. Save weight with aluminum heads, intake manifold and water pump cost $
Chris
The ford small block V8 is a 90 degree V just like the Chevy and most American V8’s.
8 hours ago, tzei said:
That's clearly Mig 19 stealth/ urban combat config. A (Farmer-X). Never made to production as it's subsonic stability was poor. ?
A few JATO mishaps led to its limited production. Yet several are still available for sale in Serbia.
1975 Malaga. It is rusty and  springs an occasional leak.  Just like me.
you b3at me to it.
TV6's work better at 60 degrees.
Or in the neighbor's pond.
