Ac parts help please
Flamingo 5
1 hour ago, Conserv said:
Thanks, Rob.
I actually have a 30101505 sitting here, waiting to go in. But when I saw 7.5 and 9.5-Amp fans, I feared the 13-Amp ...1505 might impose too heavy a load....
Feeling better now! ?
Best regards,
May I ask, at what point is it necessary to upgrade alternator?
and what upgrade requires no
alterations ?
the afore mentioned spal 505
draws 13 amps, how many amps are available to play around with on a oem alternator?
Edited by West Palm 2002
alterations ?
You should be at least considering it now, if you’re adding air conditioning. Round tailllight cars — except for tii’s, I think — have 35 Amp alternators. Tii’s and square taillights, I believe, have 45 Amp alternators. There’s a wide range of easy alternator upgrades, many from other BMW models, e.g., e21 cars, 6-cylinder cars. With many (most?) of these upgrades, the regulator is integrated into the alternator, obviating the need for a separate regulator — as all ‘02’s originally had.
Besides discussion threads, I’ll bet there’s an article regarding alternator upgrades.
YEP, here’s one:
Here’s another question
i searched Ebay and amazon
noticed the condensers were all
made in China. I’m not too keen on the quality of Chinese manufactured. I am a fan of Japanese manufactured.
i researched and found the major
supplier to oem Japanese is
( calsonic Kansei) I searched their
site but couldn’t find dimensions only model of cars used in as replacements.
i truly wish there was a sorce of
higher quality componets
This is going to be the case for all of the ‘universal’ parts I am afraid. You can scout cars at wreckers to find an equivalent size condenser and the order a new OEM part. This will also be made in China but at least Car Manufacturer X  is putting their name on the part and will stand by it until they work out you have installed it in an old German car. You may also find that the hose fittings on the condenser don’t suit the type of fittings that you might want to work with on your home brewed system.
From reading up about AC Systems in various places it sounds like you need to stand ready to replace items like driers and condensers relatively frequently as part of the usual maintenance over the longer term. With this in mind, cost and ease of replacement are fairly high up in the criteria for selection for these parts.
i feel your pain here but I think as long as you avoid the cheapest looking eBay specials you will be OK for something that ultimately isn’t a critical component on a car.
1+ with Simeon's statement.
Unfortunately, most everything we need one way or another will most likely be manufactured in China-no matter what name is put on the box.
On some hot rod forums some enthusiasts state (not sure it is backed up by reality) that if it is made in Taiwan, it will be a higher quality part,  but there are no real facts to back that up.
Just deal with a vendor that has a good reputation and good return policy. They may have a bit more interest in quality control to reduce their hassles  that the "Vendor du Jour" on Ebay.....
I bought a parallel condenser, Sanden copy compressor,  and generic AC kit on Ebay and haven't had any issues with the equipment so far.
Cheers!
My experience,  I had original Frig King A/C but needed to have compressor rebuilt, etc   so I bought all the parts and gave to 2002 AD and his a/c guys took it from there, they used the my modern compressor and mod the existing support bracket, gave me back my new bracket, new condenser, new fan and used the rest_ hoses, etc,  rebuilt my evap.. as bonus  I gave Ben a extra dash (similar to pic w/o radio)  with E. evap,  E.condenser, E fan_ as bonus.......... so someone that wants to restore to orig... Ben and A/C guys comments were as big of condenser and as big of fan as you can install you can see fan thru grille ... I notice it was pulling my alt dn (which was as I bought car) so bought 85 amp (test 100 amp and when heats up will come down to 85 amp every thing runs better,  The carb adj is when a/c on rpm is normal idle, I have the tea cup carb, w/o a/c on a little high rpm thus my mpg reduced but hot day windows up, modern radio on/vol up I am young again, just need some big trunk speakers for bimmerfest ... loved your post,  tks    L
'67 BMW 1600-2 Sahara/Brown 133,000 ..'73 BMW R90/6 Blk/White pin/s 155,000
On ‎1‎/‎12‎/‎2019 at 6:29 PM, Vicleonardo1 said:
Stick with SPAL, they are reputable for being honest about their specs and they are essentially bulletproof.
BIG time yes to this, I tried a generic CFM rated unit that blows half as hard as my new SPAL
31 minutes ago, West Palm 2002 said:
Which model is that?
My "Pre A/C" SPAL fan: 30102030 12" Swept Blade, Maximum size for Non A/C fitment.
It doesn't show in this shot but I actually did a radius cut in the top mounting bracket for more air flow.
Soon to be listed as for sale, excellent condition with mounting tabs
Edited by chargin
4 hours ago, Lucian said:
I knew I was cold … 10 min fwy … tks to Ben 2002 AD A/C guys … L
Frigiking FTW!
:D
Ray
  • 1 year later...
Based off reading a lot of your guys comments I've been searching for the parts needed to do a universal under dash kit on my 1973. For the compressor, would this work? It should be a v belt correct?
Can someone confirm all these parts if they'll work or not and if there is anything else I would need?
Thanks!
Compressor, Under Dash, and Drier
https://www.ebay.com/itm/BRAND-NEW-A-C-KIT-UNIVERSAL-UNDER-DASH-COMPRESSOR-KIT-AIR-CONDITIONER-12V/253191356013
10x18 Parallel Condenser
https://www.ebay.com/itm/CNFP1018-AC-A-C-Universal-Condenser-Parallel-Flow-10-x-18-O-ring-6-And-8/174195719099
10" Fan
https://www.ebay.com/itm/10-Inch-Radiator-AC-Condenser-Universal-Electric-Cooling-Fan-Push-Pull-1730CFM/273653939403
Universal A/C hose kit and drier
https://www.ebay.com/itm/AIR-CONDITIONING-A-C-HOSE-KIT-FITTINGS-DRIER-BINARY-SWITCH-GENERAL-USE-RAT-ROD/311102874423?hash=item486f2d2337:g:SXAAAOSwT6pVpyui
Thanks!
10" Fan
Sorry don't know how to edit this post but other things to mention and ask. The M10 I am getting installed is from a 1975. Does that change anything? I read that i'll need a compressor bracket? Any recommendations on that? Should I upgrade my alternator as well?
