BMW S2002
S2002
  • 3 months later...
  • 3 months later...
Hello guys, the stock transmission died at 18psi so now we are taking it seriously we decided to try the 2 speed powerglide that will hold 1300hp.
I will let you know the results once we have the back running.
Edited by S2002
My 235 also died under dyno at 35psi. Where you using stock s2000 gearbox? Your new powerglide will be great. Did you fab the adaptor plate?
We were using the stock ap2 transmission with a twin Disc clutch, we already knew it won’t hold but we tried to make it last. ATF made the adapter and custom build the transmission.
Read through all 4 pages.  What a great project.  Sounds mean also for a turbo car.
Not sure about the power glide direction compared to a manual trans.  I guess if u are drag racing well fair enough.
1974 2002 2.2stroker, DCOE45's, 300deg cam, 5 spd, 3.91 LSD // 1984 E24 M635csi, dogleg 5spd 3.23 LSD. // 1994 E34 540i, supercharged 16psi, 6spd E85 only, 3.15 LSD // 1997 E36 M3 Evo, low comp supercharged 18psi 6spd (under construction)
The Powerglide may be able to handle 1300HP, are you sure it can handle 9000 RPM.
Edited by allbim
Too many cars.
