Anybody Every Hear Of A Karkit Ignition Product??
I rebuilt my 32/36 and started to set the carb up yesterday and noticed that my vacuum distributor advance was bypassed. I was hooking it back up and noticed a sticker on the hood that says "This car is equipped with a Karkit, do not reconnect the vacuum advance." I have no idea what a Karkit is. Anybody have a clue??
Thanks.
1969 2002 Sahara  Manila  :)
We have a park named CarKeek here...  that's not much help, is it?
Kar Kit Emission Control System for 1955-65/1966/70 Vehicles
Air Quality Products, Inc. 1976
Orange, CA 92668
The retarded spark timing approach used by Kar Kit controls emissions solely by retarding engine spark advance and carburetor adjustment.
Kar Kit, and all State of California Air Resources Board-approved used vehicle exhaust emission control systems, uses retarded spark timing techniques. Retarded spark control systems are also used on many new vehicles. The various devices either completely or partially disconnect the vacuum advance mechanism, and some systems also retard the vehicle’s base timing for further control. Also, the systems include specific procedures for carburetor idle speed and mixture adjustment. Kar Kit is not recommended for vehicles with impaired or defective cooling systems.
All spark retard systems have the common disadvantage of reduced gas mileage and somewhat higher engine operating temperatures. However, gas mileage reduction is generally very small due to the carburetor adjustments which tend to offset this reduction. Retarding the spark timing means that the spark plug fires at a later time in the compression stroke of the engine. Retarded spark timing is accomplished with Kar Kit by (1) disconnecting the vacuum to a mechanism which causes the plugs to fire earlier under certain operating conditions; and (2) adjusting the basic spark timing to a later setting on most engines.
Retarding the spark timing can reduce the formation of oxides of nitrogen (NOx) by 40% to 50%. The effects of retarded spark timing on your engine result from the fact that gasoline is burned less efficiently in the cylinders. This can cause an increase in gas consumption, less in the city and more on the highways. Part of the increased gas consumed is burned while the gases are being exhausted from the engine, rather than on the power stroke, thus increasing the average temperature of the exhaust gases. The effects of hotter exhaust gases on your engine depend upon the engine design, and the condition of the cooling and lubrication systems. In some engines, more heat will be transferred into the cooling system. In other engines, the heat load on the cooling system may remain the same. The installation of the Kar Kit emission control system include an inspection of the cooling system and the recommended repair of defects because we can not identify the specific engines which cause added cooling system heat load. This maintenance, however, is a good idea, regardless. Test data show that leakage and poor maintenance of cooling systems are far greater problems during periods of hot weather than small increases in coolant temperatures from retarded spark timing.
Exhaust system components of all engines will operate hotter with retarded spark timing, including the exhaust valves, the exhaust manifold, and the exhaust pipes. Possible problems from hotter exhaust manifolds and exhaust pipes can be avoided by checking to see if there is sufficient clearance between these exhaust parts and other parts of the vehicle. This inspection is part of the Kar Kit emission control system.
Engine exhaust gas temperatures normally increase with greater speed and load. These increases, however, are generally greater with spark retard. On later models (1966-1970), the state requires that approved devices which use a significant amount of spark retard include a means for reducing the temperatures above 60MPH. Most approved systems (both new and used car) include an electrical or mechanical switch which restores normal timing at the higher speeds, thus reducing the temperatures. The Kar Kit 1966-1970 (NOx) approved device is designed as a simple low cost system and is recommended only for limited duty vehicles which are not operated at high speed. Therefore the system does not include the expensive switches necessary to restore timing at high speeds. The Kar Kit includes a decal which is affixed to the speedometer to remind the owner not to operate the vehicle for sustained periods above 60MPH.
Installation instructions:
The Kar Kit installation includes several steps which must be followed. They include cooling system inspection, distributor advance check, de-activation of vacuum spark advance, and readjustment of basic timing, carburetor mixture and idle speed to Kar Kit specifications.
Kar Kit use limitations:
The Kar Kit is a low cost NOx control system, designed for limited duty vehicles, and the following use limitations are to be observed. If these installation or operating limitations conflict with your vehicle condition, configuration or operating requirements, DO NOT INSTALL Kar Kit.
1. DO NOT OPERATE vehicles equipped with Kar Kit at sustained speeds above 60MPH (short periods of emergency and passing are OK). Installation of Kar Kit on vehicles which operate a major part of the time at either sustained high speed or have load conditions (such as towing a trailer) is not recommended.
2. DO NOT INSTALL on engines engines less than 50 cubic inches or on engines with distributors without centrifugal or vacuum advance.[/font]
3. DO NOT INSTALL on Volkswagen or Porsche.
4. DO NOT INSTALL on engines with impaired or defective cooling systems.Step 1) Inspection & maintenance of the cooling system
Step 2) Distributor check
Step 3) Disconnection of vacuum advance
Step 4) Ignition Timing Check and Adjustment (1966-1970)
Adjust timing at an idle speed recommended by the engine manufacturer. Set at 1° BTC on all engines except those where the manufacturer’s specified setting is:
More retarded than 1° BTC – then set at the manufacturer’s specified setting for these engines
More advanced than 7.5° BTC – then set at 1/2 of the manufacturer’s specified setting for these engines.
Step 5) Adjustment of Carburetor (1966-1970)
Adjust the carburetor idle speed and idle mixture in accordance with the manufacturer’s specifications.Step 6) Exhaust system inspection
Inspect clearance between the exhaust system and any point on the chassis. Adjust if clearance is less than 1/2”.Step 7) Documentation
Affix “limited use” decal to face of speedometer.
Install Tune-Up instruction decal within engine compartment in conspicuous location. If the vacuum advance unit on your distributor has a hose connected to the engine, you no longer have the Kar Kit installed. If the vacuum advance unit is not connected (hose is plugged), then the Kar Kit is still installed.
from the google...
Wow, gotta love the marketing that tried to hide the fact that it was just retarding the timing and disconnecting the vacuum advance. I think I could mess up my car like that without their "kit"--which seems like it was all of two stickers...
-Dave
Colorado '71 2002
'17 VW GTI Sport
If Maryland doesn't do emission inspections on 1969 cars, I'd lose the kit, reconnect the vacuum advance and set the timing to factory specs for euro cars, after removing the air pump, its associated plumbing and plugging all leftover holes.
Thanks guys.  Thought this was a piece of crap. Finally figured out that my distributor's vacuum advance doesn't work- no diaphragm!  Guess it's new dizzy or find the part time.  Any ideas on a dizzy rebuild vs. "new" dizzy??
IE Dizzy is cheap and new. Go that route. Thats what I would do.
-Nathan
there was a variant of that called the hot tune iirc, where you inserted a boot in between the spark plug and the wire, that was merely a resistor, and in some cases, a kit that was manipulating the vacuum on the dizzy, i have a R&T somewhere that made a extensive test on some kits/cars to proove that at then end even some cars lost performace and where worse on emissions !!...
the claim was 10hp gains...lol...that was in early 70's.
1985 XR4TI, 22psi ±300hp
