Tii Fuel Lines - Interest
BillWilliams
Dieter,
The original spring diameter is 14mm.
Rob
Perfect, thanks Rob.
Current:
- 1970 Colorado 2002, 1982 323i, 1972 Porsche 914, 1956 Porsche 356A Coupe replica, 2003 Mini Cooper S
Past:
- 1980 320is Turbo, 1972 Malaga 2002tii, 1973 Polaris 2002tii, 1973 Sahara 2002, 1981 Alpina C1 2.3, 1989 M3, 1984 Hardy & Beck 327S
i'd like to purchase two sets.
just a note on logistics:
i was involved with merely shipping out the original dozen or so Alpina lines 2 years ago. it would be quite an ordeal for the uninitiated to box, label and ship out 48 or more sets.
perhaps that function could be split up between several folks???
& 1 special alfa
Jerry,
I am happy to help. Located near Baltimore, MD
bill
Thanks Bill and Jerry,
I appreciate any help I can get with this. Especially, since - when the sets arrive in a month or 2 - I will be in the middle of tax season, with very little time to spare. I will do what I can, though.
Dieter
Current:
Past:
Not sure if this is a one time only production run but I am surprised at only 48 takers.
Anyone with a tii, may want to consider a set or two.
Just as a reminder, BMW is only supplying a very crude looking black flexible tube for the #1 cylinder and the word is, the #2#3 and #4 will look that way when BMW depletes their current supply of the white milky ones.
So if you want your tii fuel lines to look like the original ones, this is your opportunity.
Hi, don't care - I don't intend to do this lines only once. As I have to do this work incidently to my normal workshop jobs, it wold take a longer period to make e.g. 100 sets. Not convenient for both sides I think. Maximum 50 Sets per Order should be possible - depends on the time when you need the sets.
On Top, no littleness for Jerry and Bill (Thanks in Advance !!!) The 17 of A4 Sets which Jerry divided and sent out 2 years ago were enough - now 25 for each of them .... hmm
Now I will contact Dieter for all details concerning price and delivery to the U.S., please contact him for further details.
Thomas
Hello to all, with best wishes for the new year from Germany
As you know I don't have a cpl. engine to test the lines here, only a model of the major parts.
You will see some photos following. The first one shows the space between the throttle lever to line #4.
I've noticed that this space is mainly affected by the distance between both points (Pump and injector). One Millimeter more/less distance means about 3-4mm less/more space of the #4 line to the lever.
So, could some of you take the exact distance between both measuring points as can be seen on the photos ?
In the example at the photos this distance was 402mm between the 6mm plastic line of cyl.4 (inside-inside, not midth-midth)
This is very important, so please check.
Thanks in Advance,
Thomas
Thomas, I will purchase a complete set of lines when they are available. Thanks for doing this project for the tii community. Happy 2013! Reed
Hi Reed,
please contact Dieter, he manages the group buy (with the special price !)
Lines will be available soon after the length in the post before has been cleared.
Thomas
Taking those measurements or pictures with everything in the car is almost impossible.
However, the distance between the lever and my #4 line is very small, no more than 1mm.
The total length of #4 - measured with a slighly bent measuring tape (there is so much in the way) - is 415mm on my car. The 402mm that Thomas has sounds about right.
I hope others have better access with an engine or runners/throttle body removed. Thanks for your help - we NEED those measurements BEFORE Thomas can start production.
Dieter
Current:
Past:
I have a motor on a stand with the Kugelfischer and the injectors installed. The measurement in the above photos, 6913 and 6915 is what I measure.
I can take a photo of my measurement tomorrow to verify with you that I am measuring correctly.
1972 2000tii Touring #3422489
FAQ member #5
Good Morning,
Yes, correct Measurement is only possible when at least the manifold's first two runners are removed but the #4 pipe is installed.
Bill, I'm glad if you could state and do a photo.
Thomas
