Need High Beam Lights help
Go to solution Solved by tech71,
I installed new H4 Hella lights with high and low beam but I can only get low beam to work.  Low beam relay works fine.  High beam (HB) relay works when signal lever is pulled towards driver but HB relay does not work when signal switch is pushed away from driver.  Also, when HB relay energized by pulling on signal lever, I have power on the white wire coming out of relay using my test light but no power at wiring socket at head light. Does the wire from the HB relay not go directly to the headlights?  If not, then where?  Also, is the signal switch faulty causing the HB relay not being energized when switch is pushed away from driver?
Here is a pic of the relays... HB, LB, Horn.  Any ideas where to check next guys?
  • Solution
Looks like it goes to fuse # 11.
This looks like a job for @John76
Edited by tech71
76 2002 Survivor
71 2002 Franzi
85 318i  Doris
If the high beam flasher function works (pull lever towards you) that means the relay, its wiring and the lights themselves are all functioning, so I'd suspect the high beam stalk.  You may have to remove it from the steering column and clean the internal contacts with some tuner cleaner, then test the terminals for continuity.
I suspect John76 has a continuation of the above wiring diagram that will tell you which wires on the stalk go to which destination; that'll make checking the wires a lot easier.
Yep, Fuse 11 protects the wiring to the high beams from the relay. Likely two issues, fuse 11 and high beam switch in the stalk. Flash and high beam on both feed the white/blue wire to the relay.
The switch in the stalk could definitely be the issue, and it could be something as simple as dust in there. I had this exact issue after paint and I just had to cycle the switch ~50 times while blowing compressed air into it. Started working again.
I’d also check continuity on the yellow/white wire.  When you flash hi beams, the switch is bridging to ignition acc (green wire) to pull power. That’s why you can flash highs when the headlights are turned off. Pushing the stalk forward to turn on hi beams bridges power from the yellow/white wire, so that only works when the headlights are turned on.
 If you don’t have power on the yellow/white at the stalk when the headlights are on, it would give you the condition you mention.
Apparently a common problem. I have number 3 stalk switch waiting to go in, (#2 was supposedly good!!!) but i'm wondering if there is another reason for being able to flash the high beams with the stalk pulled but not have them come on with the stalk pushed.
Les
'74 '02 - Jade Touring (RHD)
'76 '02 - Delk's "Da Beater"
FAQ Member #17
17 minutes ago, Randall C said:
Got it fixed.  Wiggled #11 and presto.
Lesson #1 when dealing with 2002 electrical problems:
1.  Check the relevant fuse--don't just wiggle it, pull it out and inspect for wear and corrosion
2.  Check the relevant fuse
3.  Check the relevant fuse
4. If it still doesn't work it's either
    a.  something else
    b.  It's on a non-fused circuit
