Drive Shaft Bolt Size
kyalami
Go to solution Solved by tzei,
I can't believe I'm needing to ask this but I can't find anything via search either here or Google.
What size is the bolt to split the driveshaft in the center?  Looks like a 21mm or 22mm and you need to likely modify the wrench to get it to fit?  While I have the driveshaft out, I'm finally getting around to replacing the CSB that has been sitting in the garage for years...
Jason
'73 2002tii Fjord
'02 M3 Convertible Jet Back/ Imola
...then why do I have a modified 24mm wrench for taking them apart?
Hmmm.
Later versions (E21?) were held together with a bolt, but I remember that
having an even smaller head, like 17 or 19.
I'd suggest measuring it, before you grind!
it's been too long...
2 hours ago, tzei said:
This? Pos. 5
BMWFANS.INFO
Drive shaft, univ.joint/center mounting | BMW 1502-2002tii 2002 M10 Europe
Yes you need to modify the wrench.
I never needed anything other than a std Craftsman box end wrench.   Set the driveshaft section at an angle and slip the wrench on the nut.
Yup - it’s a 27mm on my car. My 1in ring wrench ground down worked just fine despite being a tad big.
Fortunately Ireland marked it when they shortened it, so all good there.
'73 2002tii Fjord
Every 2002 driveline I have ever taken apart that nut was 24mm.  Use a 12 point end wrench and you need to grind the thickness down to about 60-75% of the original thickness (Craftsman combination wrench, still have it in my tool box after 45+ years)
1970 1602 (purchased 12/1974)
1974 2002 Turbo
1988 M5
1986 Euro 325iC
Possibly an after market replacement, quite a bit cheaper and a lock nut to boot.
ea37c32626fc7228ecb6d052b282ef3f1c65bf44
BELMETRIC.COM
Bel-Metric sells metric hardware & specialty automotive supplies nationwide. Visit our website to purchase metric fasteners, nuts, bolts, Time-Sert kits & more.
Edited by tech71
76 2002 Survivor
71 2002 Franzi
85 318i  Doris
'73 2002tii Fjord
I guess I'm living right.
Your inches must be bigger than mine.
27mm is much bigger than 1 inch.
Ray
Ray
