Interior vinyl repairs
schuetz1619
Go to solution Solved by Mike Self,
I have three sorts of vinyl repairs to do. A couple could be do-it yourself jobs but I have no idea what materials to use. The third requires the recreation of missing vinyl and I don't know what sort of craftsperson to turn to.
The first of these (picture 1) is a pair of small corner-seam splits of the sides of my console. I could just fill them with black silicone but I suspect there's a better way to do this.
Number 2 (picture 2) is a tear in a door panel from a door slam onto the seat belt metal. It looks as if this could just be glued down. If so, what adhesive/technique to use?
The third is most complicated. A chunk of the vinyl is ripped or worn away from the rear upper corner of the driver's door panel, exposing the metal beneath. Are there craftspeople who can fix this? What craft? Recommendations?
Or I could replace the panel (Driver side) if anyone might have a good one for sale (late style, tan).
All help appreciated.
Edited by schuetz1619
Pix omitted
  • Solution
The repair on the console is gonna be tough, as the vinyl there is under quite a bit of tension, so you may be better off to take a big Sharpie pen, dye the filler black with it, and then glue the vinyl down as best you can with a clear glue.
The first door card repair is the easiest--a little dab of glue on the back side of the tear, then hold the piece in place with masking tape 'till the glue dries.  Put a piece of masking tape over the repair to stretch the tear all the way to its end; if done properly it will be almost invisible.
The second door card repair (at the top): you're not gonna make it perfect, but you can scavenge a little piece of matching material off the back side of the door card, especially where its stapled in the corners.  Cut the patch to fit with very small scissors, and glue in place.  Won't be invisible, but will look better than it does now.
I've had very good luck with tube glue called E6000.  Consistency of toothpaste, can be spread with a toothpick or your fingers, is not a contact cement (bonds instantly when applied to both surfaces), and dries clear.
For the Picture 1 issue, years ago I used the Permatex Vinyl Repair Kit product to repair a split in my console just inches below your split.  It was my first time using the product.  It's not perfect but I've been pretty satisfied with the results.  It's lasted all these years and blends in well with the console.  Detailed instructions in the link below so you can cogitate on how this repair will work.
Edited by yeewiz
Formatting
Bob
BMWCCA #4844 (#297 of The 308)
1974 2002 Sahara, MM 2400 Rally engine, MM 5 speed and conversion
1976 2002A Anthracite parts car
1991 525i AlpinweiB II
2002 330ci AlpinweiB III
2007 530xiT Titanium Silver
