Is this timing chain cover going to leak oil?
Eissmann
I won't use a cork gasket since the time I purchased my M3. The gasket had turned to Swiss cheese with the "rubber" degrading to allow LARGE gaps and holes allowing the oil to flow.
Paper with a quick spray of gasket sealer on both sides ..... Once and done.
Do be sure to peen the pan bolt holes back to flat before painting and assembly then tighten in stages.
+1 on dimpling the pan your #1 step to prevent a seeping gasket.. I also prefer paper pan gasket.
I couldn't handle the noise, so I used two sockets of different sizes, one on each side of the flange and a c-clamp to draw the pan.  Hammer just bounced, the pan is quite hard to reform with a hammer.
Interesting approach. Are you using the sockets on each side of the sheet metal to be flattened and squeezing with a c-clamp?
