New Pedal box with 2 brake master cylinders
Stephane
Hello,
another study i wanted to share with you is my new pedal box
I wanted to suppress the brake booster but i wanted to keep a sufficient brake force.
I made some search and i found some pics of different solutions
or this one
or this
But no solution was exactly what i search
so, i decided to built a new one
I made a study in 3d
first draw
more
I made also lot of paper mockup test
after, to finalize the study, i need to bought some equipment
I  choose also to instal a mechanical repartitor on the brake pedal
here the final design
I keep the standard clutch master cylinder
i increase the pedal brake ratio and i keep the standard electric switch for lights
I also include a new gas pedal system.  It will work with cable
Now, the build
test with engine
new pedals
the box
Final assembly
  • Like 9
5 minutes ago, Ian said:
Nice engineering!  My only suggestion would be to use remote reservoirs so you could raise them a bit higher to make servicing easier.
I think about it.  i found nice tank with 3 compartiments
but my major concern was the lot of different type of plug for hoses and i did not find something simple
I think those have hose barb fittings, and you should be able to run a simple hose up the firewall from the master cylinders to the reservoir that bolts to the firewall.
Ian
'76 M2
'02 325iT
Stephane,
I like the way you think! Well done. +1 for Ian's recommendation, remote reservoir would simplify hard line plumbing.
Make these boxes available, please. Would speed up my design plan.
Thanks
Moe
Edited by MOESPEED2002
Proud Member #190 since 2003.
Nice.
Moving the gas pedal's a good decision.  One of the things I wrestled
with was the size of my feet!  There's so little space down there for a
size 14, even if you spring for the nice OMP shoes.
How will you get the bias adjuster cable in there?  As you saw from my pics,
that made for an... interesting... clutch pedal.
And even nicer to change the mechanical ratio.
I'd bet you could sell a few, even just in kit form.
I ran the stock reservoir- Tilton supplies an 8mm nipple, and
some tubing from the VW place, and I was set.
Well done!
I think he’s referring to the cable which turns the threaded rod to move the trunnion  so that the front rear bias can be tuned. ......no?
Edited by Mike A
73 Tii stock build, Porsche Macan   , E46 330i Florida driver,
….and like most of us, way too many (maybe 30 at last count) I wish I hadn't sold ?
For the moment, i only define how the cable will be move on the pedal box side
The pedal gas is link to a lever by an adjustable rod.
red is a spring
blue are the different cable position
yellow is an adjustable stop by a screw
i tried to have everything adjustable
no Toby means the bias bar.
The whole sense of a bias bar is to be able to adjust front/rear brake ratio.
e.g. it makes sense when it's getting wet to have more brake in the rear to get the last .10ths on the track.
If you're not able to adjust without taking a wrench in the hand and taking the pedal cluster apart a proportioning valve by the hand brake lever would be better
OK, i understand
you mean the brake ratio adjustment between front and rear
As i don't plan to do lot of race track. I plan only to set a fix ratio between front and rear and not adjustable in live.
Maybe it's a mistake, i don't know
