OK to cap coolant port on rear intake side of block?
man_mark_7
Sorry for this cross-post. I posted this in the DCOE install FAQ, but the FAQ pages don't seem to pop up in the normal feed? I will post whatever answers I may get here back into the FAQ thread. So, my question:
I'm installing DCOE 40s. I have the IE water bypass to go from the back of the water pump to one side of the heater core. I just noticed there is a port on the back end of the block that used to route to the old intake manifold. Is it OK to just plug this port? I don't want to create any hot-spots on the block!
thx
Mark
  • 2 months later...
34 minutes ago, WhoIsSea10 said:
How exactly would you cap that off? I'm in the process of installing a dual carb with the coolant bypass pipe. Not sure what to do with this thing.
Single barrel carb'd engines had a manual choke and this port was not used.  So BMW put a straight threaded plug with a crush washer in there.
Item 3 & 4
76 2002 Sienabraun
2015 BMW F10
Hang onto the nipple fitting if you remove it.  From time to time there are WTB FAQ'ers looking for them.
Edited by jimk
52 minutes ago, TobyB said:
This advise is only advised between consenting adults.
no piercings here
Well. We all have our vises.
Ray
