Block and components colors
Beantown
Hi All,
I got my block back from the shop today and was very happy with the color.  I had plans on painting it black but they did some kind of coating that is gunmetal color.  I was wondering if anyone knew what color the block and components came from the factory?  Also wondering what everyone else is doing?  I am thinking of keeping the block this color and then all the aluminum parts painted and aluminum color,  then painting the valve cover this gunmetal color too.  Thoughts?
Thanks
Edited by Beantown
The factory finish on the block was black. All aluminum components, e.g., head, valve cover, etc., had a natural finish (no finishes applied).
Do whatever you like!
Totally agree with Steve, totally your call.
That finish is pretty sexy however.
Jason
1973 2002tii (2764167), Baikal, sunroof, A/C, 5spd OD, 3.91 LSD, etc. Rebuild blog here!
--> Blog: Repro tii cold start relay;   --> If you need an Alpina A4 tuning manual, PM me!
Yup.  Do it the way you'll like it.
"Thoughts?"
I like the black block.  I also like bare aluminum intake manifold and valve covers.  Let metal be metal, I say.  It looks honest, that way.
A lot of people prefer powder coating aloominum color (AKA plastic coating), or clear coating the aluminum.  Both are attempts at keeping it looking newer-than-new.  Newness is overrated, in my opinionionion.
Those people are all doing it wrong.  Don't be one of those people...
unless you want to... in which case, you should do that.
Vapor honing is all the rage now; replacing Krinkle-Koat-Black on the fashion charts.
Once in a while I rub a little oil on the valve cover, so it doesn't dry out and turn chalky.
Tom
  • Like 5
That looks good I use light gray on the block because IMHO it will show oil and coolant leaks the best and will allow you to trace them back to the source easily.
Hi Bibm5,
Its actually not the same block.  Because I decided to bore it out to use 89.47 piano top pistons,  I decided to use the block that came with the car.  But, I am using the 2.0 crank that came in the block that I bought from you,  which will make my 1.8 block a 2.0!  I honed the bore in the block I got from you and it looks great, but didn't want to bore it if it wasn't need.  I guess I will CL that one or make a turbo back up engine!  ha!  Did you end up buying that 320i from Asheville?
Look at both blocks they will have casting dates on them. As to the size of the water openings in the block it makes no difference the water flow is controlled by the  size of the connecting holes in the head gasket
10 hours ago, Beantown said:
Y'all got me looking closely at the two blocks I have and I noticed the coolant channels are smaller on the machined block than on the non-machined block. Is this an earlier casting or later?IMG_0808.jpg.e174cefa3d84007a2396eb461a5b684b.jpgIMG_0809.jpg.e543168cabcdbb58066a0b7281a8ef9f.jpg
Look at the blocks’ casting dates and engine numbers!
The casting dates are on the right side, in the vicinity of the number one and two freeze plugs.
Here’s a thread telling more about locating and reading casting dates:
The engine numbers are on the engine’s left side, at the very rear of the block, stamped into a flat machined boss, as shown below on my ‘76.
Edited by Conserv
Sorry. I didn’t see that you had answered this already!
Best regards,
Edited by Conserv
