Unknown ignition system component
OldBlue2002
I am prepping my '02 for a changeover from my 20 yr old msd ignition setup to a 123ignition distributor.
While tracing a wire from the distributor's condenser connector over toward the drivers side of the engine bay, I found that it connects to a part I can't identify (see picture). It seems to be covered in tape and has been there ever since I first got the vehicle (2003). Any idea what it is? I don't see it in any wiring diagrams or engine bay photos around the web.
Also, I am under the impression that some components (resistor) are discarded when upgrading to the msd 6a. Will any of that be put back in now that I'm switching back to only having a distributor?
Thanks,
Scott
Edited by OldBlue2002
Clarity
That is likely a tacho converter. That’s there to drive your tachometer as the signal from the MSD is incompatible with your factory tacho. If you are removing the whole MSD then you can remove it too. If you are going to switch the MSD using the 123 then leave it in place.
Looks like a transformer.  At a minimum, it will have four wires, one pair for each winding.  If you can trace the wires to see where it connects, we may be able to deduce its function.  If only one winding (two wires) is connected to anything, it is being used as an inductor.  Do you have the stock tach in the car?
hmm, interesting.
I was actually asking jimk about his tachometer, because I remembered this post from one week ago
I actually have a newer version, or at least I assume it is newer, based on it being plastic; since that seems to be the way things go.  (I have no use for it.  Photos are fun though, so here you go : )
12 hours ago, '76mintgrun'02 said:
was that the one that fried your tach?
No, it was a new tach adapter.  Black goo was oozing out of the adapter when I got home from the MidAmerica02fest.  It happened 2 years ago.  Delux Speedometer in Denver rebuilt the tach with a new board and now I don't need an adapter.
The one in the pic above looks to be an newer version still than the one that crapped out on me.
  • 1 month later...
Uhh...maybe a remote windshield washer pump (non-OEM)? Where do the hoses lead?
ooh...originally a sienabraun-metallic car?
Edited by Conserv
I run a 123 with a msd and it works amazing. Just use a solid rotor or you will melt it down.
"Goosed" 1975 BMW 2002
