Where do I put collant?
Ronan
You can get standard radiator caps which have a solid rubber seal rather than the pressure reliever spring design. Probably somewhere like Summit or Jegs in the US.
Use a pressure rated hose and hose clamps on the overflow to radiator hose.
rtheriaque wrote:
I have a story like Dudelands, I was going out with a girl in high schooland while she was driving us around in her Chevelle it overheated, so I opened the hood and lifted the bleed tab on the rad cap when it stopped hissing I removed said cap and had hot coolant sprayed all over my face and chest fortunately only 1st degree burns so we went to her house for first aid and to clean up and  wash my shirt, resulting in my 1st co-ed shower.  turned out that a flake of rust had plugged up the vent on the rad,It could have turned out a lot worse ;).
George S Patton
52 minutes ago, Son of Marty said:
... resulting in my 1st co-ed shower.  turned out that a flake of rust had plugged up the vent on the rad,It could have turned out a lot worse ;).
She's quite the ingenious one to plant a flake of rust in the system so she could take a shower with you.  Damn.
One of the biggest advantages of an overflow is that there is, eventually, no air in the cooling system.
No air= no oxygen.  No oxygen= no oxides of iron, aluminum, or boron.  Or borons.
Also no co- ed showers.
So don't run an overflow tank!
