E30 rear end, axles, brakes, etc into a 2002
jakeb
This is something I have been wanting to do for a while now.  One weak point for a 2002 with high power is the rear end and CV joints.  I am currently building a 2002 with a nissan SR20Det for a customer and he is going to be making somewhere in the 300hp range.  While a small case diff MIGHT be able to handle that it won't handle it very long and not with much abuse.  Even with a super strong built small case diff the CV joints become the weak point.
the e30 stuff is known to handle a good amount of power and it a close match to the 2002.
The only way I would want a e30 setup in a 2002 is if the track can stay the same.  I would not want something that requires flares, etc.  Also I wanted to keep the possibility of keeping a stock 2002 driveshaft (or e30 shaft)
So first step is to build a jig that locates all the 2002 points.
Next step is to remove all the 2002 parts and replace with SOME of the e30 stuff.
Now all there is to do is start connecting the dots...
This picture before is just to show an idea of where the new subframe will live and how it will be shaped.
This setup will use the following.
e30 diff
e30 trailing arms
e30 rear disc brakes
shortened e30 axles
2002 subframe bushings
2002 sway bar
custom spring perch (maybe 2002 perches cut from 2002 trailing arms (still unsure of this right now)
This will be something I will be reproducing and selling.  The kit would come with a custom subframe, diff mount, spring perches (will need to be welded to e30 trailing arms), and shortened e30 axles.
I will continue to post in this thread as we make more progress.
1985 e28 w/LS1/t56 and a bit more...
1970 2002 w/ m42 swap
-Contact me for m42 mounts or e28 ls1 mounts-
www.classicdaily.net
Something to consider if you haven't test fit anything yet, the medium case diff will hit the trunk floor if the input flange is located in the same position as the 02. Are you actually taking the axles to someone to have them shortened, or are they going to be a new production version of the e30 axles, just shorter?
New M20 swap mounts when I get around to welding them up. I should make this font smaller because it may never happen...🙃
'71 2002 Restomod under the knife, 2012,...2018, 2019 it will run again! 2024? IDK
'74 260z K24 swap
Very well done!! I will be installing a medium case diff on a stock subframe soon, so if you want you compare notes I would be happy to do so.
1974 Grey European Market BMW 2002
1976 Yellow BMW 2002 "GOLDENROD" SOLD
1972 Yellow Austin Mini 1000
A bunch of Bikes...
Jake......
very very cool....I knew u were doing this..... our turbo owner is getting antsy.......I just hope he controls his new found hi po car....lol.....
I know I cant wait to drive it.
I am excited to drive it as well.  I really should put a build thread over here of that car.  It is on my website here.
 http://www.classicdaily.net/category/current/bmw-2002-sr20det-swap/
Out of curiosity - have to time it out for my build - when do you think you are going to have these available to buy? Have looked at the CATuned rear subframe assembly and have heard of another so timing will help make a decision
Cheers
Edited by 2002newb
