Shifter bushings
TTyMiller
I installed a set Polyurethane shift bushings on my 76 i want to say they wear produced by ATK motorsport but cant say for sure. but i know Ireland doesnt produce them. anyway they are totally bullet proof iv bin owning and maintaining 2002's for 25 years and have replaced loads of shift bushings for varios reasons but mostly gear oil getting on them and destroying them. I know thers alot of people that hate Polyurethane bushings but these are worth taking a look at.
You have to actually get under the car to do this work.
If you haven't done so in a while, you should also check out your guibo, center support bearing, rear universal joints, clutch hydraulics, etc.
Even better, find a place with a lift (or two or three...)
  • 13 years later...
Be sure to check/replace the link with a cross pin.  That assembly added a lot of slop to mine.
Do you have the early or late style shifter (shown above in c.d.'s images).
I have the late style and the link/pin assembly are parts # 1-6.
Part(s) # 21 (2) are plastic and wear out as well.  I used bronze bushings there.  There are old threads showing that process.
