What other parts do I need for a 5 Speed swap
So i just recently acquired a 5 Speed Getrag overdrive tranny from a fellow 02er around the area. It is my understanding that aside form the transmission itself i will also need a few other things.
These are the few things I have so far
- The 5 speed Getrag Tansmission with clutch disk, pressure plate etc.
- 5 speed shift plate from Ireland Eng.
- Shirt shift Kit from Ireland
- Bushings for cross member
so what else do i need besides a cross member for the tranny a longer speedo cable and a suitable drive shaft?
74 white beauty
Just a n00b...that wants to shit out flames!
Caution for those buying 6-hole guibos from BavAuto (as in my list above):
That one was crappy, flexed too much and shredded the outer edge against my shift rod after only 2 short test drives. ONLY purchase genuine Febi/Bilstein guibos. I replaced the BavAuto one with a good one from BLUNT.
depending on how much money you want to spend, a conversion can be done for half the cost of the above list.
please due elaborate I have so far
- 6 hole guido from IE
-longer speedo and trans link cable
- short shift kit
-215mm clutch kit with proper throw out bearing,
-cross member
-245 getrag 5 speed
- trans mounts
might install with help of friend or take to shop as i have no tools for a job like this.... thats pretty much the only thing holding me back and a drive shaft..
74 white beauty
- short shift kit
-cross member
-245 getrag 5 speed
- trans mounts
i bot a 5spd+driveline+shiftplatform for $800
short shift kit pieces $125
guibo $50'sh
228mm clutch kit $240
323i throwout bearing $60'sh
new clutch slave cylinder $50'sh
new clutch master/slave hydraulic line - fabbed at a local hydraulic shop $35 ($70 bucks for a 18" hydraulic line is highway robbery)
viola
email blunt for part quotes
he can do better on pricing than almost anywhere i've bought parts
72 2002tii
1988 535is  “Maeve”
  • 8 years later...
