Furniture dolly for engine drop
rapandi
I am planning on dropping my engine, gearbox and subframe as a whole unit this weekend. My research shows that some people have opted to use an ATV jack or a furniture dolly.
I am thinking of going with the cheaper option which is the dolly and the one locally available here has a MAX capacity of 350kg or 770lbs.
Am I going to be calling it too close with that capacity of the dolly? Does anyone know?
http://www.supercheapauto.com.au/online-store/products/SCA-Flat-Movers-Dolly-350kg-76-x-46cm.aspx?pid=342171#Recommendations
Edited by rapandi
Raj
1972 BMW 2002 Tii - Golf Yellow
How do you plan to lift it back into the car?
I used an overhead grab with a comealong.  If car is not raised high enough for the engine on the subframe, lift the engine first, slide the subframe under, lower engine onto the mounts, lift both up in place holding against rails with a floor jack in addition to the overhead pull.
I got it out sorta in reverse but just laid the engine on it's side on cardboard and slid it out.
We have cheaper ones over here: http://www.harborfreight.com/18-in-x-12-14-in-1000-lb-capacity-hardwood-dolly-61899.html I have a dressed M20, subframe & gearbox on the one I just linked. You won't have any issues with the weight.
If you can, pick it up in the store vs. online. I've recently had a bunch of issues with castors not being centered properly (the wheels don't roll evenly) with an engine hoist, a floor jack and a moving dolly (all with metal wheels). Place it on the floor and roll it to make sure the wheels roll properly. Trust me, it is a pain in the rear end to learn the hard way that your wheels won't roll evenly once weight is added. All three of those issues were Harbor Freight products. All of which harbor freight was happy to let me return/exchange.
E36
I used a telescoping A frame ladder, a couple of 2x4's and some ratchet straps to lift a motor off the sub-frame (that happened to be sitting on furniture dollies) to put on an engine cart.
Plans are to use the same things to put the motor back on the sub-frame from the cart.
your mileage may vary.
I am mentally dissecting the best way to drop the motor and transmission out of the car ( why would you do anything else?).
So far...
I am running the rear wheels up on lifting ramps.
I am jacking up the front of the car to match, perhaps in a couple of lifts, to align with the. Front ( big jack stands under the frame rails with timber).
I am attaching the engine to a block and tackle or engine hoist.
I am unbolting everything and lowering the front subframe, engine and transmission down to a furniture dolly
I am pulling the dolly out having bunched up my struts
Could maybe drop the engine with the floor jack, could maybe just drag stuff out without the benefit of the furniture dolly.
rtheriaque wrote:
