Furniture dolly for engine drop
rapandi
I see your problem. Perhaps this is a peculiar issue to RHD necessitating removal of the exhaust manifold and a bit of careful wiggling as you drop the subframe?
If you are suspending the engine etc by a hoist then you may be able to rotate the assembly slightly in the engine compartment. Pulling the steering column seems drastic for a few inches.
You should be able to get the coupler further up the steering column. No reason, in theory, why the column shouldn't pass right through the coupler but probably easier if you split the coupler by undoing the two nuts on the studs and pulling the coupler and bottom joint out to make some space.
Edited by Simeon
rtheriaque wrote:
