Source for flat lens H4s?
Andy74tii
'64 R27 250cc #383851 18,000m
I have a pair of Bosch 7" headlights that are flat lensed with replacable H-4s. Looking to sell them. I replaced them with Cibies which are a bit convex.
Hooked on 2002 since my first one bought new in 1972
Initial cost isn't too bad.
It really starts to add up later as you have to replace them one at a time when they get cracked from rocks. I just reached the point where I don't care. It's got a crack? Oh well.
It should be a straight plug in on a 76 as you already have a headlight relay for the circuit. As long as you go with a bulb at 55/60 or so, there should be no problems with the current draw. If you start going for higher output like the 100 watt lamps, then you should add in a separate wiring harness for the lights. The separate harness is not a bad idea even with the lower wattage lamps. You gotta remember you're dealing with 35 year old wires/connectors/switches.
Steve J
& too many bikes
I have Hella's, Bosch and Stanley H-4 headlights and while they are not completely flat, but they are a lot less "bulbous" than the standard sealed beam headlights are.
Fishhead
Motorcycle Big Brake systems
Be yourself and be free with your thoughts because those who matter don't mind and those who mind don't matter..
Check out the Euro Bosch H4s at The Bus Depot. $44.95 - for a pair! Also German H4 60/55w bulbs for $3.95 each. I had been looking at getting some Hella units from rallylights.com but I jumped on this deal when I was buying some parts for my '85 Westfalia camper.
http://www.busdepot.com
These replaced the 30 year old pitted and oxidized reflector Cibie Z-beams on my late '71 2002. Drove it last night and was so impressed what fresh headlights can do :-) I'm currently using the 39 year old stock wiring but I plan to upgrade to a new harness with separate relays for the high and low beam circuits.
These Bosch headlights have a much flatter profile than the Cibies, looking just as flat as the Hella H4s I put on the Vanagon years ago. They are labeled "Motorcycle" on the lens and they don't have the inner shield as most automobile H4 units do. Here's a link to more info. on sealed beam vs H4's and these specific Bosch headlights:
http://www.ratwell.com/technical/BoschH4.html
- Bill B.
Napa, CA
Current BMWs:
- late 1971 2002 - second owner - purchased Aug. 1979
- 1988 M6
Previously owned: 1969 2002, 1972 euro 3.0csi, 1982 633csi, 1982 r65LS
According to several others on this site, you do not have to change the buckets.
1974 polaris A 4281992 (total resto with 5-spd conversion)
1976 jadegrun 2744974 (sold then killed by the new owner, grrrr!)
1976 sahara A 2392532 (sold)
1971 nevada 2571108(RIP)
